7805 heating
Results 1 to 11 of 11
Thread: 7805 heating
    Jan 2007
    Brazil
    Default 7805 heating
    Hello..
    i developed an application (12f629) to turn on or off my car using the alarm control. To stabilize the voltage i've used the 7805 regulator. I've used 4 relays in this project. It is draining at most 250mA when the 4 relays are on. This situation of 250mA draining can occur for 40seconds and no more than that. Is it normal for the 7805 to get hot? Should I use a heat sink?
    ps.. i can let my finger on it when it's full loaded.
    thanks...
    Sylvio
    Sep 2003
    Vermont
    Quote Originally Posted by sirvo View Post
    Hello..
    thanks...
    Sylvio
    Yes...and yes. You are dissapating ~8 volts at .250A which is two watts. I believe the regulator will eventually fail without an adequate heat sink. You can also put a 6 volt .25A bulb in series with the battery supply line to drop the voltage. The advantage to this is you will know when the relays are activated.
    Ron
    Jan 2006
    Istanbul
    It should be normal if there is no heatsink.
    Why don't you use a heatsink or a kind of metal plate to attach it?
    Find a metal part around your circuit and use it as a heatsink.
    Jan 2007
    Brazil
    ok. Thank you both. i'm gonna find some heat sink.
    thanks a lot..
    sylvio
    Jan 2007
    Brazil
    again.. do you think that a heat sink of 1 cm² ( 0,155 sq. inch) is enough?
    reminding you that the ~2W are wasted in at most 40 seconds and rarely this will be wasted 2 times consecutively...
    thanks again,
    Sylvio
    Mar 2006
    Hyderabad (India)
    Hello..
    thanks...
    Sylvio
    Hi, what if you kkep relay coils on unregulated voltage and release the burden from 7805?
    Sarma
    Sarma
    Quote Originally Posted by mvs_sarma View Post
    Sarma
    That is doable, I would switch the relays with a transistor to protect the pic.
    Jan 2007
    Brazil
    it is working very well since i plugged the heat sink on 7805 regulator..
    no more heating at all.. thanks,
    mvs sarma.. i would like to do that but i've already bought some 5V relays.. and my supply is 12V ..
    Joe S. - yes, that is what i have done.. i've used four bc337 transistors to switch the relays...
    Sylvio
    Mar 2006
    Hyderabad (India)
    Sylvio
    Hi, what if? you canadd a resistor series to the coil to limit the current, or you can use the transistor in emitter foller mode where the volage at emitter is less than the voltage at base.
    Sarma
    Thumbs up
    Hi, Sarma
    V. Good idea ...
    If you use a series resistor AND a capacitor between resistor and ground ( say 100 to 470 µF ) you will have enough energy to power up the relay ... and the resistor will limit the quiescent current ...
    Jan 2007
    Brazil
    sarma.. yes, it was a possibility.. but now it's done.. thank you for giving solutions... next time i'll use this information..
    Sylvio
  1. Better Alternatives to 7805 ?
    By Art in forum General
    Last Post: - 21st December 2009, 09:21
  2. 24VAC Transformer from Air Handler, 7805
    By nemesis in forum Schematics
    Last Post: - 25th February 2009, 19:23
  3. 7805 works fine, LM2940CT5 not!
    By DanPBP in forum Off Topic
    Last Post: - 29th August 2007, 22:01
  4. Candle Warmer - heating Element
    By teverett in forum mel PIC BASIC Pro
    Last Post: - 6th December 2006, 01:37
  5. 7805 regulator + diode
    Last Post: - 14th June 2006, 20:45
