yeap.. happen to me the first time.. u said u send $00 keystop u mean as the USBout buffer right.. tht should do the trick.. but if it doesnt then proly it could be the simple things like maybe u were sending a variable out and u didnt clear the variable to $00... always clear after sending them once.. wat i do is clear before sending and after sending.. just a suggestion if it still repeating then proly its just a small routine mistake somewhere..
one mroe thing the scan key routine i did would check for special modifier keys first.. keep it in a variable then check for normal keys and add them to the variable.. then only u send it out..
It's great when the penny finally drops with this USB stuff!
