Conversion of bytes to word
Results 1 to 12 of 12
    In a world of german electrons
    Default Conversion of bytes to word
    Hello. In short:
    -converted word to write it with
    WRITE 0, WValue.BYTE0
    WRITE 1, WValue.BYTE1
    -numbers are written to the pic i can see them having read it with my programmer
    -how to convert these two hex-values to one word again ?
    selbstdual
    the same way dude.
    READ 0, WValue.BYTE0
    READ 1, WValue.BYTE1
    No. I want to see a value between 0 and 65536.
    PS: Don't call me "dude".
    Talking
    << No. I want to see a value between 0 and 65536. >>
    I suppose it must be a word ???
    << PS: Don't call me "dude". >>
    Ok, no problem, we won't any more, dude.
    Feb 2003
    Quote Originally Posted by selbstdual View Post
    Not possible Im afraid.
    Although having declared Wvalue as a Word and read the upper and lower bytes back into it as per Mister_E's example, you should find that Wvalue contains a value between 0 and 65535.
    You can output this on a display with
    LCDout DEC Wvalue
    LCDout HEX Wvalue
    or any of the other many ways that PBP can format numbers.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    In short:
    -let pic collect data, write to eeprom
    -put pic in programmer
    -read pic's eeprom
    -shows something like
    2100: E0 02 1E 04 74 04 C1 05 à...t.Á.
    2108: FC 06 5D 06 C5 08 0F 08 ü.].Å...
    2110: E9 07 95 09 76 0A E1 09 é.•.v.á.
    -means: E0 02 is one pair, 1E 04 is the next one and so on
    -want to see a number between 0 and 65K instead of pairs like "E0 02".
    Well, dude, you won't see 65536 represented in a standard word. You'll have to use 17 bits instead of 16 to get 65536.
    Talking A good question is always half the answer ...
    A good question could be WHAT do you want to use to read your EEPROM ???
    - LCD DISPLAY : Mr E Gave you the answer ...
    - IDE : ah ...yes, maybe here we are !!!
    I use MPLAB, and ... I use a side calculator ( Win.calc or here Casio Fx 880 ) !!!
    No Other way in MPLAB ...
    Lightbulb
    You couldn't even distinguish a chair from a table and would sit on the table while wondering how to eat on the chair. This is great for comedy.
    What's wrong with that?
    Have you defined the height of the table and the chair? I think not...
    Nor have you defined the PIC you are using, the version of PBP, which pages of the PBP manual you have looked at, which datasheets you have downloaded and studied, any websites you may have visited for information on some basic programming exercises...the list goes on...
    Thumbs down Selbstdual, Maybe ... but half brain !!!
    1) a Fair answer to those who can't follow your "High level Brain" wouldn't be too much, moreover it could show you're a bit clever.
    2) The last program I wrote kept side by side bits, Bytes and Words in the EEPROM ... How do you think your IDE could know by itself where are the different variable kinds ???
    3) Try to learn how to use the WRITECODE and READCODE function ( with the convenient PIC !!! ) ... If his majesty would dare !!! ... dude.
    4) another solution is to export the EEPROM content as a text File ... and decode it with an Excel sheet ( using VB Macros ...).
    'Have to Learn a bit before wanting to seat at the PIC Gurus table. ( I just serve the wine there ... and I'm really proud of it !!! )
    Jun 2007
    Germany
    WVValue.BYTE0 = WVValue.BYTE0 * $100
    WVDVal = WVValue.BYTE0 + WVValue.BYTE1
    Last Post: - 14th June 2016, 07:55
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Minimizing code space
    Last Post: - 30th May 2009, 07:25
  4. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 8th July 2008, 23:19
  5. calculation problem
    Last Post: - 31st March 2006, 15:23
