Serious Serial Situation Setbacks...
Results 1 to 6 of 6
    Default Config fuses
    G'Day Dan,
    Ask the dog if he set the config fuses properly, or maybe you can set them in code for him Which compiler are you using, MPASM or the default PBP compiler?
    Look at this thread: http://www.picbasic.co.uk/forum/show...t=config+fuses
    Feb 2007
    Near Chicago,Illinois USA
    Smile Moving Forward!!!
    I am using ceramic resonators. But I do have x-tal's and will switch them out. Out of curiosity why does it matter? I chose the ceramic's because they consume less space.
    Fuses... That's something I've never heard or read about before (in PIC language).
    I'm using MicroCode Studio 2,2,1,1 and PBP version 2.46.
    When I select to "Compile and Program" the "meProg" initiates and I can select to view the configuration window. Do I have to do anything other than select the correct oscillator?
    Quote Originally Posted by Dansdog View Post
    Xtal vs resonator - xtal=tight tolerances, resonator=not quite so tight; required if you're using any kind of communications
    fuses - see the PBP manual, page 8.
    Feb 2007
    Smile Ahhhhhh......
    Thanks skimask!!!
    Page 8 might become next favorite page....I'll let you know tomarrow.
    Dan
  1. Replies: 33
    Last Post: - 19th March 2010, 03:02
  2. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 17:03
  3. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  4. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 22:35
  5. Replies: 2
    Last Post: - 23rd July 2006, 08:16
