RA3 won't get a high level.
Results 1 to 15 of 15
    maybe because your Pauseus 244 is way too high? try to remove it.
    In a world of german electrons
    This is right. It should be 40.
    But.
    I found out that the circuitry itself acts as a huge capacitor compared to this one.
    I replaced it with 58 pF and threw away my calculations. Now it's time
    to experiment....
    I am using it ratiometrically but the same value doesn't seem to exist two times.
    Wert:
    	ADCWert = 0
    	Trisa.3 = 0
    	High Porta.3
    	;Pauseus 800
    	Trisa.3 = 1
    	WHILE Porta.3 = 1
    		ADCWert = ADCWert + 1
    	WEND
    	Trisa.3 = 0
    	Low Porta.3 ;To make UC = Vss
    	Pauseus 100 ;To make UC = Vss
    Somehow the capacitor has to have time to charge, having a too high value for Pauseus doesn't affect the measurement, it makes sure that the cap is surely charged. But here I cannot know when it's surely charged, but this must be more than zero.
    I did some testing. This is the result: Max = maximum value of the resistor, InB = In Between. Pause = Pause to load the cap.
    		Max	InB	Min	Min	InB	Max
    Pause 3		46336	54273	16388	8965	48132	30980
    Pauseus 5	39433	54025	11274	64777	11529	27145
    It should be in the form of x² or -x². But both show strange behaviour.
    Do you have an idea ?
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. confused problem with interrupt in a working program
    By illuminator4 in forum mel PIC BASIC Pro
    Last Post: - 14th November 2008, 18:01
  4. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  5. Serin and TMR0
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 17th May 2006, 15:58
