Hi All
i am use pic16f84a and hd44780 and i am connect the circuit and prgramed
this code
' PicBasic program to demonstrate operation of an LCD in 4-bit mode
' LCD should be connected as follows:
' LCD PIC
' DB4 PortA.0
' DB5 PortA.1
' DB6 PortA.2
' DB7 PortA.3
' RS PortA.4 (add 4.7K pullup resistor to 5 volts)
' E PortB.3
' RW Ground
' Vdd 5 volts
' Vss Ground
' Vo 20K potentiometer (or ground)
' DB0-3 No connect
Pause 500 ' Wait for LCD to startup
loop: Lcdout $fe, 1 ' Clear LCD screen
Lcdout "Hello" ' Display Hello
Pause 500 ' Wait .5 second
Lcdout "World"
Goto loop ' Do it forever
and the output only draw blockes in first line
please heeeeeeeeeeeeeeelp meeeeeeeee
