data storage prior to use, whats the best way here?
Results 1 to 7 of 7
Threaded View
  1. #6
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by enigma View Post
    I`m reading in data from an A/D conversion approx once a second. I need to store these to a total of 20 readings in a way which overwrites the oldest reading as each new reading is added. Should one data element exceed a limit between two values I need to send the stored data as serial output consisting of the 10 values prior to the event and also the 10 values after the event.
    Pete,
    You are looking for a ring or circular buffer. Sayzer gave you a bit of code to look at. Here is another approach.
    ; PIC16F877A
    High_Limit     CON 196
    Low_Limit      CON 64
    ADC_Value      VAR BYTE       ; Latest ADC Reading
    Buff_Pointer   VAR BYTE       ; Current spot in Buffer
    Buff_Len       VAR BYTE       ; Number of Values in Buffer
    History        VAR BYTE[10]   ; Last 10 ADC Readings
    Remaining_Vals VAR BYTE       ; Number of Values left to send
    Counter        VAR BYTE
    ; Initialize values
    Remaining_Vals = 0
    Buff_Pointer = 0
    Buff_Len = 0
         ADCIN 0,ADC_Value
         IF (ADC_Value > High_Limit) OR (ADC_Value < Low_Limit) THEN  ; Check Limits
         ; Out-of-limits
              IF Buff_Len > 0 THEN ;There is something in Buffer
              ; Send out Contents of Buffer Before Current Value
                   FOR Counter = 0 TO Buff_Len - 1
                        IF Buff_Pointer + Counter > 9  THEN
                             HSEROUT [History(Buff_Pointer + Counter - 10)]    ; Output Value
                             HSEROUT [History(Buff_Pointer + Counter)]    ; Output Value
                   NEXT Counter
                   Buff_Len = 0             ; Reset Buffer
                   Buff_Pointer = 0
              HSEROUT [ADC_Value]      ; Send out current Value
              Remaining_Vals = 10      ; Set count so next 10 Values will be sent
         ' Within Limits
              IF Remaining_Vals > 0 THEN    ; post out-of-limit values to be sent
                   Remaining_Vals = Remaining_Vals - 1
                   ;Add Value to Buffer
                   Buff_Len = Buff_Len + 1
                   IF Buff_Len = 11 THEN
                        Buff_Len = 10
                        Buff_Pointer = Buff_Pointer + 1  ; Move Pointer to 2nd oldest
                        If Buff_Pointer = 10 THEN Buff_Pointer = 0  ; Wrap Around
                   IF Buff_Pointer + (Buff_Len - 1) > 9 THEN
                        History(Buff_Pointer + Buff_Len - 11) = ADC_Value
                        History(Buff_Pointer + Buff_Len - 1) = ADC_Value
    GOTO Main
    It will check each reading. If it is out of limits, it will send the contents of the buffer (which could be less than 10 if the out of limits occurs before 10 readings), then send the current ADC readings, then send the next 10 readings.
    If, while sending the 10 readings after an out of limit condition, it will reset the counter and send 10 more readings.
    It is set up to use HSEROUT, so you will have to change that as neede to suit your purpose. Also, you will need to setup the ADCIN as well.
    You should have plenty of material to get this going.
    HTH,
    SteveB
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
