Pic reseting when switching mains current with relay
Results 1 to 23 of 23
    malc-c's Avatar
    malc-c Guest
    malc-c
    I think you misread something or... could be me too
    Could of.. but I thought the problem was with the relay causing the PIC to reset when the lamp is switched
    Quote Originally Posted by lsteele View Post
    I'm trying to switch a mains current (240V AC) with a relay connecting via a transistor to my PIC (a 16f876a). The PIC is powered from a battery supply - 4 rechargeable AA NIMH cells providing 5V. That's powering the PIC directly - there's no regulator (I presumed there's no need for one).
    At the moment the mains supply is hooked up to a light. Everything usually works fine when switching the relay ON, but when the relay switches OFF the PIC resets almost every time.
    This was why I commented on the use of SSR's which I've used directly dirven from the PIC and don't suffer any issues of then PIC re-setting. However if I've missed the plot (quite plausable ) then sorry for taking the thread OT !
    malc-c's Avatar
    malc-c Guest
    Just looked at the thread again and I think we're at cross purposes as there seems to be a thread with in a thread... I was responding to Luke's original question in post #1, and not shahidali55's in post #17
  1. Reducing PIC current to as low as possible...
    By FromTheCockpit in forum mel PIC BASIC Pro
    Last Post: - 18th November 2009, 05:28
  2. Replies: 24
    Last Post: - 7th November 2008, 05:41
  3. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 18:42
  4. Detecting mains current
    By lsteele in forum Schematics
    Last Post: - 13th January 2007, 15:48
  5. High current switching output
    Last Post: - 8th September 2005, 15:06
