>> If you didn't change the default config fuse while loading the Bootloader firmware the first time, you can't modify them later in your code.
I know! :-) But I'm quite happy with that fuse configuration right now... unless it's a factor in my problem.
>> Yes the snubber will help!
>>also
>> * Make sure you have connected both PIC VSS pins.
>> * Make sure you have disable the LVP mode
>> * Set all unused i/o to input and connect ALL of them to GND
>> * i would add a 47-220 uF on the PIC VDD line as well (close to the PIC)
>> * Place your PIC away of your relay to see what's happen.
Ok, I'll try all of the above. But I'd like to understand why connecting a 47 Ohm resistor across the relay output (as part of the snubber circuit mat suggests) is a good thing -- surely it'll allow a current to flow all the time. Or have I misunderstood something?
Thanks again...
