Key Pad Project
Results 1 to 6 of 6
Thread: Key Pad Project
    Aug 2005
    Houston, TX
    Default Key Pad Project
    I want to display my project as requested, but I don't see any way to attach the .gif files for the circuit board and circuit, or the .bas file for the program, or the .txt file for the notes???
    Help!
    AMay
    AMay
    The best way would be to zip all files up into one then click on reply look towards the bottom and you will see a button saying manage attachments click on that a new window will open (if not check your pop up blocker if you use one) in that window you will see browse (find your zipped up file) then when you come back to that window click the upload button once uploaed click close window then click submit reply
    regards,
    chuck
    Aug 2005
    Houston, TX
    Found it. I'll try without the .zip, as they are not very big. I will change the .bas file to .txt first.
    AMay
    Jun 2006
    Quote Originally Posted by AMay View Post
    AMay
    ok , i am waiting.....
    Aug 2005
    Houston, TX
    Default Key Pad Project again
    Attached should be .gif files for the circuit board and circuit, .txt files for the PICbasic program and notes.
    OK the .gif files are too big. I'll try again.
    Aug 2005
    Houston, TX
    Default Key Pad Graphics
    Here are files that should work.
    The Copper file is a high quality actual size x-ray view that can be used to make a circuit board.
    The copper top and circuit are OK I hope.
    "Zipping" the files did not save very much.
    Have fun,
    AMay
  1. 8x8 keypad matrix...
    By mbox in forum General
    Last Post: - 9th October 2014, 18:43
  2. Complete Keypad Example
    Last Post: - 27th July 2011, 19:09
  3. Replies: 3
    Last Post: - 10th April 2008, 10:02
  4. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 04:26
  5. Key Pad Matrix
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 30th November 2004, 23:50
