A Bit manipulation brain teaser for you :)
Results 1 to 14 of 14
    Jan 2006
    Istanbul
    Quote Originally Posted by dw_picbasic View Post
    The 4 bytes represent a value from 0 - 30,000.000
    Can you split 30,000 from .000?
    If you can, then you can put 30,000 into a word variable, and the remaining three zeros (.000) can get into another word variable (in theory).
    If of course this is only for display purposes!
    how the data is sent? Did you tried to attach your radio directly to a PC? Maybe he just send you ASCII string or HEX value?
    in fact it could make sense... let's assume it send you 4 Bytes...
    30,000.000
    Jan 2007
    Yes, the device is setup to talk to a PC.
    The PC queries the device for its set frequency, and the device returns the 4 bytes.
    I know I should push the 4 bytes into 2 seperate 16 bit words.
    Then I need to figure out what the decimal part is for:
    Millions
    Thousands
    Hundreds
    This seem pretty straight forward for a 1 byte word, but no so easy for me to get my head around doing it for 2 bytes, due to the carry effect.
    if you have a LCD, you can do a simple test
            HSERIN [ByteA, ByteB, ByteC, ByteD]
            LCDOUT $FE,1, HEX2 ByteA, HEX2 ByteB, HEX2 ByteC, HEX2 ByteD
    What's happen using that?
    Any model or link to your radio?
    Jan 2007
    Talking
    I think I got it !!!
    I created a program using VB which simulates the PICSs math processing.
    I realized that.
    1. Even though there are 32 bits sent all together, only 26 of them are used.
    Since the devices highest achievable number is 30,000,000.
    2. The 5 highest bits with their corresponding multipliers directly effect the 1,000,000s place.
    3. The 16 highest bits with their corresponding multipliers directly efffect the 1,000s place.
    4. 18 of the bits directly effect the 100s place
    So what I do is create 3 bytes.
    Symbol MHZ = B5 (8 bit word)
    Symbol KHZ = W3 (16 bit word)
    Symbol Hz = W4 (16 bit word)
    Then I go down through the 26 bits 3 times.
    The first run down looks at each bit and applies that bits MHZ multiplier adding these values to MHZ
    The second run looks at each bit and applies that bits KHZ multiplier adding these values to KHZ
    Any time KHZ goes > 999, I do the appropriate carry to MHZ
    The third run looks at each bit and applies that bits HZ multiplier adding these to the HZ value
    Any time HZ goes > 999, I do the appropriate carry up through KHZ and MHZ.
    Now all I have to do is transfere this code into PBC.
    I hope to get that done tonight.
    ** this is where a simulator program comes in real handy!! **
    My next step on this project is to slice some specific frequency windows into numbered slices so that the pic can control a second device based on a reading falling within a specific slice.
    I love this stuff!!!!
    Last Post: - 14th June 2016, 08:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  3. Sleep Mode
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 11:31
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
