A Bit manipulation brain teaser for you :)
Results 1 to 14 of 14
    Jan 2007
    Red face A Bit manipulation brain teaser for you :)
    Hey Gang, let me know if you have "done that - got my T-shirt" and know the answer to this one.
    I have 4 (8 bit) bytes being sent to me in a serial string.
    Byte_1 is to be multiplied by 16777216
    Byte_2 is to be multiplied by 65536
    Byte_3 is to be multiplied by 256
    Byte_4 is to be multiplied by 1
    These are all then added to be converted into their decimal equivalent.
    I can do this in a PC no problemo
    But how do do it in a PIC where your greatest mathmatic result is limited to <= 65535?
    I have played around with sum divisions by 1000, and seem to almost get there until I have to deal with adding Byte_4s value to the result.
    Interested in your suggestions
    Jan 2006
    Istanbul
    Default A friedly idea!
    Write a flip flop code for a PIC to flash couple of colorful LEDs.
    Stick that PIC on your PC motherboard; connect to the +5V of PC power supply.
    AND pretend as if the PIC were doing the math for you
    Jan 2007
    Cool!..... Yes,
    Then I could write a book and title it "Picing up the PC"
    Well, you place those limitation yourself. You could still use 2 Words... some basic maths around that. But will this worth if you could do most of the job on your PC side? It's up to you.
    I don't want to pretend I know the answer but may have an idea....
    What do you intend to with the value once (if) you have it?
    /Henrik Olsson.
    Not exactly a Brain Teaser - more a trick question.
    Byte_1 is the MSB of a 32-bit variable, Byte_4 is the LSB of your 32-bit variable... no maths needed... so what you're really asking for is a routine to output a 32-bit (four byte) variable in human readable decimal...
    Jan 2007
    Hi Melanie,
    I thought I posted this the other day, but perhaps the system kicked me out for not posting fast enough.
    The 4 bytes represent a value from 0 - 30,000.000
    So fortunatly for me, the highest Byte will only be a 1 or 0.
    The numbers represent radio frequency.
    I have a radio that is sending me the 4 bytes to indicate what its current frequency is.
    I have a number of frequency windows to play in.
    I split each one of these windows up into 8 slices.
    The frequency value then gets matched to one of these slices.
    I use this info to control a remote antenna tuner box I made last winter.
    I would bet you call this one simple.
    But its over my head
    Duane
    Feb 2007
    Default wat is multipication?
    multiplication by two is same as shifting left once in binary base. ( as multiplication by 10 is same as shifting left once in base 10). so multiplication by
    16777216 = 2^24 = shifting 24 bits left.
    65536 = 2^16 = shifting 16 bits
    256 = 2 ^8 = shifting 8 bits
    1 = 2^0 = no shift.
    and division is shift right...
    Jan 2007
    Hi CagDask,
    Thanks for the post.
    I ended up using a combination of PBC and assembler.
    I put bit multipliers into eeprom and read them based on a bit test for each of the 15 bits. All values greater than 999 go into W2 and all above that into W3. I'm reading the serial data in at 57.6K also with an assembly routine and 20Mhz crystal.
    Here is one of the routines.( W2 collecting Mhz & Khz ) from byte 3. (the one that is has 65536 as its multiplier). I played around with simple division, but I kept loosing remainder values and with them resolution, so this seemed pretty easy. Its basic double precision addition in assembly, with each bit multiplier value being read from eeprom. W3 >= 1000 carrys into W2 and I'm getting really good resolution.
    B0 = 0 'start of eeprom
    B15 = B12 'take copy of byte 3 into B15
    W2_B12:
    B1 = B0 + 1
    Read B0,B2
    Read B1,B3
    IF B2 = 0 AND B3 = 0 Then exit_W2_b12
    asm
        btfss    47,7 ;ram 47 = B15 ;if the bit is high add its multiplier
        GoTo    NO_W2_B12
        movf    34,w    ;ram 34 = B2 which now has LSB from eeprom
        addwf    36,f    ;add this value to ram 36 = W2.LSB
        btfsc    3,0    ;check status register carry bit
        incf    37,f    ;if carry occured, increment ram 37 which is W2.MSB
        movf    35,w    ;ram 35 = B3 which now has MSB from eeprom
        addwf    37,f    ;add MSB to W2
    NO_W2_B12
        rlf        47,f    ;rotate B15 left one bit
    B0 = B0 + 2
    GoTo W2_B12
    exit_W2_b12:
    Last Post: - 14th June 2016, 08:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  3. Sleep Mode
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 11:31
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
