Hello Everyone,
Still in an effort to understand this programming language, I now am playing with DIV32.
I have taken the code from the manual and added some serial routines so I can view whats happening. I have posted the code below.
The code does what the book says it should do. I have a couple of questions:Code:' Use MPASM @MyConfig = _HS_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _LVP_OFF @MyConfig = MyConfig & _CP_OFF & _BODEN_OFF & _DATA_CP_OFF @ __config MyConfig Define PIC16F628A define OSC 20 include "modedefs.bas" a var word b var word c var word Dummy var word start: b = 500 c = 1000 disable ' dummy = b * c a = div32 100 enable serout PortB.4,T9600,[254,1] pause 100 serout PortB.4,T9600,[254,128,"dummy is:",# Dummy] pause 1000 serout PortB.4,T9600,[254,192,"A is:", # a] pause 1000 serout PortB.4,T9600,[254,148,"B is:", # b] pause 1000 serout PortB.4,T9600,[254,212,"C is:", # c] pause 1000 goto start end
the line, a = DIV32 100 . I get that the 100 causes DIV32 to divide by 100, what I do not get is how DIV32 knows to use the math in the above formula, is "Dummy " a default place holder? My second question is the value of Dummy as outputted in line 1 of the display, I get the fact, 5 hundred thousand is too large for 16 bits to hold but 41248 makes no sense to me, can anyone explain?
Thank You
JS
