i2c PBP questions
Results 1 to 15 of 15
    This device support high speed I2C clock... no need too add I2C_SLOW define.
    Double check that you didn't revert SDA & SCL and that you have place 1 pull-up (4.7k or lower) on SDA and SCL lines.
    Forget the ICD stuff and try this one
            '       Device configuration fuses
            '       4MHz Clock     ---------> XT
            '       WatchDog Timer ---------> ON
            '       PowerUp Timer  ---------> ON
            '       BrowOut Detect ---------> ON
            '       LowVoltage programming -> OFF
            @   __CONFIG _XT_OSC & _WDT_ON & _PWRTE_ON & _BODEN_ON & _LVP_OFF
            '       If you're using PM assembler, you must change the above line
            '       for the following
            '       @   DEVICE PIC16F877A, XT_OSC, WDT_ON, PWRT_ON, BOD_ON, LVP_OFF
            '       Hardware configuration
                    '   I/O PORT
            TRISC = %10000000
            TRISD = 0
            TRISE = 0
                    '   USART
                    '   Baudrate = 19200
            DEFINE HSER_RCSTA 90h               ' Enable serial port & continuous receive
            DEFINE HSER_TXSTA 24h               ' Enable transmit, BRGH = 1
            DEFINE HSER_SPBRG 12                ' 19200 Baud @ 4MHz, 0.16%
                    '   ADC
            ADCON1 = 7                          ' set all related i/o to digital
            '       Hardware assignments
                    '   I2C BUS
                    '   4.7K (or less) pull-up resistor on SDA & SCL line
                    '   24LC512
                    '   A0 - A2 pin -> GND
                    '   WP pin ------> GND
            SDA var PORTC.4                     ' I2C bus SDA line
            SCL var PORTC.3                     ' I2C bus SCL line
                    '   LCD
                    '   4 bits mode
                    '   Data DB<7:4> -> PORTD<7:4>
                    '   RS -----------> PORTE.0
                    '   E ------------> PORTE.1
                    '   R/W ----------> GND
                    '   Vo -----------> 10-20K Trim pot wiper
            DEFINE LCD_DREG PORTD               ' LCD data port
            DEFINE LCD_DBIT 4                   ' LCD data starting bit
            DEFINE LCD_RSREG PORTE              ' LCD register select port
            DEFINE LCD_RSBIT 0                  ' LCD register select bit
            DEFINE LCD_EREG PORTE               ' LCD enable port
            DEFINE LCD_EBIT 1                   ' LCD enable bit
            DEFINE LCD_BITS 4                   ' LCD data bus size
            DEFINE LCD_LINES 2                  ' Number lines on LCD
            DEFINE LCD_COMMANDUS 2000           ' Command delay time in us
            DEFINE LCD_DATAUS 50                ' Data delay time in us
            '       Internal EEPROM assignement
            data @0, "Good",13,10
            data     "Bad ",13,10
            '       Variable definition
            ADDR            var word
            Data_READ       var byte
            Data_Write      var byte
            IsBad           var bit
            TotalBad        var word
            PicEepromAddr   var byte
            Char            var byte
            '       Software constants
            Control         con $A0             ' 24LC512 control byte
            '       Program start
                    '   Hardware and software initialisation
            PORTC = 0
            PORTD = 0
            PORTE = 0
            clear                               ' clear all variable
            pause 500                           ' LCD start-up delay
            lcdout $FE,1                        ' clear LCD
                        '       Send repport header via serial communication
            hserout ["    ADDR    Data_Write    Data_READ    Good/Bad",13,10,_
                     "    ----    ----------    ---------    --------",13,10]
                    '       EEPROM write, read & test loop
                    '       1) write to EEPROM the LowByte value of current
                    '          address (ADDR) value.
                    '       2) read it back and compare results
                    '               case it's different:
                    '                   set 'IsBad' flag bit
                    '                   increment 'TotalBad' variable value
                    '       3) Show results on LCD
                    '       4) Send results via serial communication @ 19200 bauds
            For addr=0 to $FFFF
                IsBad=0                         ' set as good results
                data_write=addr.lowbyte         ' get the LowByte of current EEPROM
                                                ' address
                I2CWRITE sda,scl,control,ADDR,[data_write] : PAUSE 5
                                                ' send it to the EEPROM and
                                                ' wait max Twc delay
                I2CREAD  sda,scl,control,ADDR,[Data_read]
                                                ' read the current data
                                                ' at the current address
                if data_read != data_write then ' data stored is different?
                                                '    YES!
                    IsBad  = 1                  '    set bad result flag
                    totalbad = totalbad + 1     '    increment total of bad result
                        '       Show data on LCD
                lcdout $FE,2,"W:",hex4 data_write,"   R:",hex4 data_read,_
                       $FE,$C0,"TotalBad=", dec totalbad
                        '       Send data via serial communication
                                '   Show : Current address
                                '          Data_Write
                                '          Data_read
                hserout [rep " "\4,hex4 addr, rep " "\7, hex4 data_write ,_
                         rep " "\10,hex4 Data_read,rep " "\8]
                                '   Show if the actual reading is "Good"
                                '   or "Bad"
                for piceepromaddr=(IsBad*6) to ((IsBad*6)+5)
                    read piceepromaddr, char    ' read character from PIC EEPROM
                    hserout [char]              ' send it
                    next
                next
                    '       *    the whole job is done    *
                    '       Show the amount of bad results
            hserout [rep " "\4,rep "="\43,13,10,_
                     rep " "\4,"TotalBad = ",dec totalbad,13,10]
            lcdout $FE,1,"TotalBad=",dec totalbad
    SpinHere:
            goto spinhere                       ' spin in round forever
    Jan 2007
    Toronto
    Hi Steve:
    Thanks for the suggestions and the code. I am just building my proto type board, and so far, I have the LCD working and 2 dual segment 7 segment displays running off a MAX7219. That is all that is working at this time. I am trying to get the i2c working next.
    I do not have the rs232 link working yet, so I can't implement your suggestion below.
    I have confirmed the SDA and SCL connections at the IC with a meter on the pin while single stepping the code. I am getting 2.03 volts at both SDA and SCL and I do have a 4k7 resistor on each line.
    The ICD 2 is both my debugger and my programmer and it is my only interface to the 16F877a at the moment.
    I will check all the wiring as I have prewired the DS1307 and DS1631 sockets. They checked out with a meter when I tested SDA and SCL, but I will have a close look again.
    thanks
    tim
    Jan 2007
    Toronto
    Hi:
    I did some rewiring as I have found in the past that a particular type of 8 pin socket that seems to be the only kind I can get has caused me problems. I wired an 18Pin socket of the type I like for the 24AA512 and the DS1307.
    As embarrassing as it is, since this is a forum and a post that someone else might read and benefit from, here is some information that should be checked. (And more than once it seems)
    Pin 7 on the EEPROM is WP (Write Protect). If it is high, you cannot write to the EEPROM. I had missed the mark by one tiny little hole on my proto board and wired WP high.
    I discovered this after rewiring to the new socket and having the same problem writing to the EEPROM. This time, I had forgotten to add the wire for WP at all. I measured with the meter and found that if left floating, WP will be high.
    I destroyed the EEPROM by accidently by taking too long to clear a solder bridge with the iron when trying to wire WP low.
    So, I have moved on the the DS1307 RTC. I have yet to read back the config properly (I get "16") when I send the value LCDOUT, $FE, $80, #CONFIG where "CONFIG" is the value sent after Year to address $07. I think that is telling me that I am reading "FF" from the config register which I know from previous experience is telling me that I am not talking to the DS1307.
    It was getting late, and I packed it in. I will have another look at it tonight.
    Sorry to have missed the WP on the EEPROM. Too bad I burned it out. I was hoping for the best.
    If I can't get the DS1307 to run properly, I will move on to the One-Wire phase of bringing the board on line. Hopefully that will not be a difficult as the i2c has been
    thanks for the help
    Tim
  1. explanation on I2C command (PBP)
    By F1CHF in forum mel PIC BASIC Pro
    Last Post: - 12th May 2014, 06:30
  2. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 19:27
