i2c PBP questions
Results 1 to 15 of 15
    When you write ADDR=$07 or ADDR=$7, it store $0007 to the word variable in one shot...If you prefer in the MSB and LSB. have Look to your EEPROM datasheet...
    http://ww1.microchip.com/downloads/e...doc/21754E.pdf
    Look Figure 6-1. What happen if your address variable is a byte? Yes it miss the LowByte of the address. Using a word sized variable, nothing is missing.
    Nothing else to worry about, I2CREAD/WRITE will do the job for you.
    P.S. : Welcome on the forum Yet another Canadian Woohoo !!!
    Jan 2007
    Toronto
    Hi Steve:
    Thanks for the response. Happy to strengthen the Canadian contingent
    I am sitting here watching the program run on the ICD. I wish they went faster.
    I will confirm that the address stuff is exactly as you said. I watched 8 0s get fed before it put in my address and I am now watching shift my address across.
    From what I can see, everything is working properly.
    When I let it run, I am expecting to see the number contained in the [] brackets on the write statement returned in my byte i2c_Data which is in the [] brackets in my read statement.
    If this correct?
    The read statement does not hit the "Fail" after the [] so that would imply that the program is "running".
    Tim
    Running or at least it says that there's something on the I2C lines.
    If you really want to know if it's working, you could still write to the EEPROM, then read back the data, if both are the same... it confirm it's working.. just fine.
    Jan 2007
    Toronto
    Hi Steve:
    Well that is my big question in my previous response. If this was doing what it is supposed to be doing, would I not see the result in my i2c_Data variable?
    ADDR var word
    ADDR = $07
    PAUSE 10
    I2CWRITE PORTC.4,PORTC.3,$A0,ADDR,[1]
    PAUSE 10
    I2CREAD PORTC.4,PORTC.3,$A0,ADDR,[i2c_Data],Fail
    PAUSE 10
    GOTO MAIN
    Fail:
    PORTC.5 = 1
    GOTO MAIN
    I would expect i2c_Data to contain "1"
    It does not.
    Am I giving everything enough time?
    Tim
    Try this one, it's working here
    define LOADER_USED 1
    disable debug
    Data_READ   var byte
    Data_Write  var byte
    Bad         var bit
    ADDR        var word
    SDA         var PORTC.4
    SCL         var PORTC.3
    Control     con $A0
    Bad = 0
    Start:
        For addr=0 to $FFFF
            data_write=addr.lowbyte
            bad = 0
            I2CWRITE sda,scl,control,ADDR,[data_write]
            PAUSE 10
            I2CREAD sda,scl,control,ADDR,[Data_read]
            enable debug
                data_read=data_read ' refresh ICD display
            disable debug
            if data_read != data_write then bad=bad +1
            next
        GOTO Start
    Jan 2007
    Toronto
    Hi Steve:
    Thanks for posting the code. How long should this take to complete? I can see that it is cycling through addresses 0 to $FFFF. I put in a line between the next and GOTO Start to light up one of the status LEDs I have on the board.
    It is not lighting up. In the watch window, Data_READ is blank. When I pause the program, I am in the library PBPPIC14.LIB stuck in the PAUSE routine waiting for the carry bit to be cleared. This bit does not get cleared.
    I just thought of something. I have no includes in my program as I normally did with assembler. I am just starting out with PBP.
    Am I perhaps not adding some includes that I need?
    I didn't see a list in the manual anywhere of any special requirements that have to be in the code. I don't have a device include either.
    Please advise
    Tim
  1. explanation on I2C command (PBP)
    By F1CHF in forum mel PIC BASIC Pro
    Last Post: - 12th May 2014, 05:30
  2. I2C Master/Slave 16F88/16F767 working code
  3. HARDWARE I2C SAMPLE CODE question
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 19:33
  5. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 18:27
