Ok thanks that helps but what does it mean its floating?
That mean the VCC is floating or when the ADC is connected to nothing its floating?
The ADC input is floating and the reading is meaningless if it has no connection.
I am stuck again.
I multiply by 1000 to shift where the decimal will be.
The problem is my first calculation is
1022*1000 comes out 38960 instead of 1022000 How do I keep my whole number?
I tried this as well
dummy VAR WORD
adval0=1019
dummy = adval0*1000*3
adval0 = div32 1023
Gives me 111... Should be giving me 2988 or something...
Try this...
Code:adval0 = adval0*3000 adval0 = div32 1023
Stuck again. I'm just not understanding this math
adval0 = 2904
result = adval0 / 15100
remainder = adval0 // 15100
result = 0
remainder is 2904
How do I get the acutal number it should be 0.192xxx?
I'm looking at dig but not sure if thats the right thing to use because it will not always be 2 digits...
adval 0 = 2904*10
result = adval/151
192
then use dig to move the places... and do something like
if > 9999
if > 999
to figure out where the . should be... Is this the best way to do it?
