Battery checker
Results 1 to 19 of 19
Thread: Battery checker
    Sep 2006
    Default Battery checker
    hello
    i wrote this program below. I am putting the Vref- on the lead of a fourth diode in series . There are 4 diode connected in series so that there is always 1.6v . I assume the Vref+ and Vref- is always 2.6 differnce. It is doingan A/D convertion on a voltage divider with a max voltage of 2.5.
    The problem is that My lcd always shows me 373 (10 bit a/d) no matter what the voltage input is. Any idea what is wrong.
    SO , I have a voltage divider on the battery to bring the voltage down. Right now I am reading 1.03v with a supply at 4.57 and on the 4th diode I am reading 2.98v.
    My voltage divider I have Vdd -51Kohm -15Kohm- Vss
    'Battery test for transmit pic
    INCLUDE "modedefs.bas"
    @ DEVICE PIC16F88 , HS_OSC , WDT_OFF , PWRT_ON , BOD_ON , LVP_OFF , PROTECT_OFF
    DEFINE OSC 20 'use external 20mhz crystal
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    ' Define ADCIN parameters
    ADCON1 = %10100010
    TRISB = %00000000
    input1 var word
    loop:
    ADCIN 0, input1
    'pause 30
    Lcdout $fe, 1 'Clear screen
    Lcdout "Left: ", Dec input1
    Pause 100
    Goto loop ' Go back to loop and blink LED forever
    Sep 2006
    I got it working but have no clue why .
    If i do what is on the pic :
    http://www3.sympatico.ca/lerameur/
    then it works.
    In this manner the output voltage also moved at the same time as the reference voltage no ?
    Sep 2006
    Talking
    Anybody ??
    Wink Rtfds !!!
    I think ( ! ) a look to the '88 Datasheet ( ADC config ) could help you a bit ...
    PS: common diodes as voltage refs ... that's a bit rock and roll ...
    Sep 2006
    I just changes the circuit a bit. I have new ideas this morning. night was good.
    I am getting 1.06v steady on the diode as reference. My voltage divider shows me 0.7, but I am getting zero as output now.
    Is it the hardware or the programming ?
    I posted a new pic.
    also changed this line:
    ADCON1 = %10010010
    ken
    brianwu's Avatar
    brianwu Guest
    Quote Originally Posted by lerameur View Post
    I posted a new pic.
    ken
    Picture show you have both input connected to same place (ref. diode), resistor divider left unconnected.
  1. Of battery discharge curves
    By ardhuru in forum General
    Last Post: - 21st January 2009, 16:24
  2. Low battery signal from an RTC
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 19th March 2008, 17:13
  3. Replies: 1
    Last Post: - 20th December 2005, 03:56
  4. Help with setting adcon1 for 16f877
    Last Post: - 16th August 2005, 11:13
  5. Battery backup with long delay
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 6th January 2004, 20:38
