SERIN2 @ 38400 @ 40mhz
Results 1 to 9 of 9
    pssst... PicMultiCalc do this for you
    http://www.mister-e.org/pages/utilitiespag.html
    But frankly, i would use DEBUG instead if you don't need multiple serial ports.
    If you use the internal OSC... you better forget it...
    Right, I know about the PicMultiCalc, works like a champ.
    If I use the hardware UART on the PIC, a modified version the software works great, but I lose the ability to use SERIN2's character handling capability, which is really handy.
    This tells me that possibly the SERIN2 runs just a bit off spec at 38,400 baud.
    When I get the software finished up, I'll permanently switch over to the hardware port and write my own routines to handle strings and such as needed.
    Internal OSC? Obviously the only time I trust that is at 2400 and below, without calibrating anyways. After calibration, I've used it successfully up to 115,200.
    ... but I lose the ability to use SERIN2's character handling capability, which is really handy.
    As far as I know, HSERIN does everything SERIN2 does. STR DEC HEX BIN etc.
    What's missing?
    What's missing?
    DOH! Forgot about HSERIN.
    You're right, nothing missing, any software timing differences aren't a factor...
    The serial port pins are already used up by another serial interface running at the same speed, but much less critical. I'll just have to do some rewiring. I don't know why I wired it like that in the first place
    SWEET! At least I have a manual
    Wink
    ROFL, so you're one of the few having it here AND you missed ...
    Quote Originally Posted by TFM
    HSERIN supports the same data modifiers that SERIN2 does.
    Just kidding
    Eeeeese a good ONE !
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 15:48
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  3. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 16:21
  4. help
    Last Post: - 9th February 2005, 21:42
  5. Need once your help one please
    Last Post: - 9th February 2005, 21:33
