SHIFTIN problem
Results 1 to 3 of 3
Thread: SHIFTIN problem
Threaded View
    Nov 2006
    Default SHIFTIN problem
    hi all. More rookie problems to deal with. I am using the SHIFTIN command to shift in 16 bits of data from a counter. My problem is with initiating the counter's shift register. The following link will lead you to the data sheet for the decoder/counter that I am using.
    http://www.genapta.com/WORD%20DOCS/GEN-2122-5.pdf
    On the 5th page under "Shift Register" you will read that in order to latch the data to the shift register I have to hold PLsr high for one rising edge of the shift register Clock, CLKsr. My problem with that is the SHIFTIN command is what generates the pulses for CLKsr, and I am forced to manually drive CLKsr high while PLsr is high in order to latch the data. As a result, I always miss the first bit. Not good. I need a way to latch the data as the SHIFTIN command begins. Does anyone know a trick I could use to do this? Thanks.
  1. USART Problem , but don't know where, in pc? or in PIC?
  2. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  3. PIC18F458 Shiftin / Out
    By pberhin in forum mel PIC BASIC Pro
    Last Post: - 29th May 2006, 21:36
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. weird 12F629/675 problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 7th October 2004, 02:08
