ASM Addressing method help needed
Results 1 to 2 of 2
Threaded View
    Feb 2005
    Kolkata-India
    Unhappy ASM Addressing method help needed
    I am trying to read and buffer LPT printer port data by a 18F452 @ 40MHz. The application is a parallel to serial converter. I am using INT_0 high priority interrupt to read the strobe (falling edge) signal and capturing the data via portd. As soon as I fall into the ISR I clear the INT_0 flag , locate the address (which array what location) where to store the data and return ( RETFIE FAST ). I have found that creating a software indexed array addressing method eats up instruction cycle time. ( I haven't counted my instruction cycle time, but I am loosing data). So rather than using 5 different arrays I plan to use a single array starting from Bank1 through Bank5.
    So my questions are:
    1. Is the post increment method the best here ?
    2. While in the interrupt if the INT_0 flag gets set can I loop around my ISR before quiting ?
    3. How to define and access my array (1280 bytes @ 8bit data buffer) ? Cause without a software index I don't know where was it left and what has been already transmitted serially and what pending ?
    4. Can somebody help me with the LPT port timings to decide if it is at all possible with a PIC ?
    5. Would it be beneficial to use the PSP port ?
    I am counting on the Gurus out there and I am desperate even to overclock the PIC to 48MHz. Please help.
    Last edited by sougata; - 28th January 2007 at 16:34. Reason: Added question no. 5 PSP mode
    Sougata
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 15:45
  3. PBP, ASM and LST files
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th January 2010, 14:43
  4. ASM help
    Last Post: - 21st October 2009, 04:08
  5. Problem with ASM IRQ using FSR0 on PIC18F252
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 21:48
