Hmm, the 16f648A is what I'm using too, since that's as much memory as I can find in an 18 pin chip, but I read that to do the code space thing, that you have to enable "Flash Program Write", but that option is disabled when I choose that chip? Maybe I got that mixed up with something else I was reading about. If I do another board layout, I'm going with probably the 16f916. It has more pins and I think it was 8K of memory. Also, there are several others that I can swap out with it to get a ton of memory if needed....Live and learn. Let me show you what you guys have helped me do though. I have went from way out of space down to 3344 words.
Here's the EEPROM statements:
EEPROM 0, [1,1,10,0,0,0,24,1,1,150,0,250,0,1,1,0]
EEPROM 30,["R","e","a","d","y",0]
EEPROM 36,["D","e","l","a","y",0]
EEPROM 42,["1","5"," ","S","e","c",0]
EEPROM 49,["2","0"," ","S","e","c",0]
EEPROM 57,["1"," ","M","i","n","u","t","e"]
EEPROM 65,["2"," ","M","i","n","u","t","e"]
EEPROM 73,["5"," ","M","i","n","u","t","e"]
EEPROM 81,["E","n","t","e","r",0]
EEPROM 87,["A","c","t","i","v","i","t","y"]
EEPROM 95,["D","b","l","e"," ","P","i","c"]
EEPROM 103,["S","e","n","s","t","v","t","y"]
EEPROM 111,["H","i","g","h",0]
EEPROM 116,["M","e","d","i","u","m",0]
EEPROM 123,["L","o","w",0]
EEPROM 127,["D","a","y","N","i","g","h","t"]
EEPROM 135,["2","4"," ","H","o","u","r"," "]
EEPROM 143,["D","a","y"," ","O","n","l","y"]
EEPROM 151,["D","a","r","k","O","n","l","y"]
EEPROM 159,["W","a","l","k","T","e","s","t"]
EEPROM 167,["S","t","r","t","W","a","l","k"]
EEPROM 175,["E","x","i","t",0]
EEPROM 180,["C","a","m"," ","T","y","p","e"]
EEPROM 188,["O","N","/","O","F","F","-","1"]
EEPROM 196,["O","N","/","O","F","F","-","2"]
EEPROM 204,["A","l","w","a","y","s","O","n"]
EEPROM 212,["R","e","f","r","e","s","h"," "]
EEPROM 220,["S","h","u","t","t","e","r"," "]
EEPROM 228,["S","l","v","R","f","r","s","h"]
EEPROM 236,["S","l","v","O","n","T","m","e"]
EEPROM 244,["3","0"," ","S","e","c",0]
EEPROM 251,["7"," ","M","i","n"]
'The vars:
LCDtext VAR BYTE[8]
EEnum VAR BYTE
LCDtextNm VAR BYTE
LCDtemp VAR BYTE
LCDnum VAR BYTE
EnumC VAR BYTE
'Some of the code:
Select Case Mode
Case 1
Delay = Delay + 1
IF Delay > 7 Then Delay = 1
delmode:
Select Case Delay
GoSub lcdone ' Position cursor at home
EEnum = 36
GoSub EEtext
' LCDOut "Delay"
GoSub lcdsec ' Move to 2nd line on LCD
Case 1
GoSub TENsec
' LCDOut "10 Sec"
TimeDely = 10
Case 2
EEnum = 42
GoSub EEtext
' GoSub fteenSec
' LCDOut "15 Sec"
TimeDely = 15
Case 3
EEnum = 49
GoSub EEtext
' LCDOut "20 Sec"
TimeDely = 20
Case 4
EEnum = 57
GoSub EEtext
'LCDOut "1 Minute"
TimeDely = 60
Case 5
EEnum = 65
GoSub EEtext
'LCDOut "2 Minute"
TimeDely = 120
Case 6
EEnum = 73
GoSub EEtext
'LCDOut "5 Minute"
TimeDely = 300
Case 7
GoSub TenMin
'LCDOut "10 Min"
TimeDely = 600
End Select
Pause 400
'The SUB:
EEtext: LCDtextNm = 0
Pause 10
LCDnum = 0
EnumC = EEnum
For EEnum = EnumC TO EnumC+7
Read EEnum, LCDtext[LCDtextNm]
Read EEnum, LCDtemp
Pause 10
IF LCDtemp = 0 Then
LCDnum = 1
EndIF
IF LCDnum = 1 Then
LCDtext[LCDtextNm] = " "
EndIF
LCDtextNm=LCDtextNm+1
Next
LCDOut STR LCDtext
Thank you all for the help! This will get me down the road a ways.
Gary
