reading IR photoresistor
Results 1 to 10 of 10
    Quote Originally Posted by mbw123 View Post
    dhouston, you said that I should send a ultrasound pulse to find distance. But how would I track the position of a specific object (one with a IR emitter, for example) without using anything too complex or expensive like a camera? Thanks for any advice.
    -Mike
    How about triangulating the angle between 2 narrow angle IR sensors mounted on seperate servo driven platforms X amount of distance apart? That would give you relative position and distance. Put in on a motor driven platform and you can follow anything...
    Sounds like fun doesn't it?
    Jul 2006
    Uh oh, I smell a difficult project ahead if I were to try that. If I stuck with what I am doing (IR emitter and receivers) , what difficulties would I run into as far as measuring distance using just IR?
    -Mike
    May be THIS could help ???
    http://www.kronosrobotics.com/an120/AAN120.shtml
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 18:51
  3. Plz help in completing RC-5 IR remote lamp dimmer project
    By vu2iia in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 08:44
  4. PIC10F200 Automated IR Light Switch
    Last Post: - 3rd May 2007, 11:40
  5. how to get pic to pic communication
    By kinsiro in forum mel PIC BASIC Pro
    Last Post: - 30th August 2005, 17:12
