I2C PCF8574 4X4 Keypad routine
Results 1 to 3 of 3
    RFsolution, Here ia a snipit of code I wrote back somewhere in 2003. I hope this helps....
    I2CWRITE SDA,SCL,UNIT0,[%11110000] 'ALL COLLUM LINEs LOW
    AGAIN:
    GOSUB READKBD
    GOTO AGAIN
    READKBD: 'READ DIGITAL INPUTS FROM KEYBOARD
    KEYDOWN = 1
    I2CREAD SDA,SCL,UNIT0,[KEYPRESS] 'LOOK FOR SWITCHES DOWN
    KEYPRESS = KEYPRESS >> 4
    IF KEYPRESS < 15 THEN 'KEY NOW BEING PRESSED
    IF KEYFLG = 1 THEN 'KEY ALREADY BEEN FLAGED & PROCESSED
    GOTO DONEKEY
    INCDEC = 1 'INCREMENT DEBOUNCE COUNTER
    IF DEBOUNCE = 65535 THEN '16 Ms. THRU ROUTINE TO KEY
    FOR JUNK = 0 TO 3 'CYCLE THRU COLLUMS
    I2CWRITE SDA,SCL,UNIT0,[~(DCD JUNK)] 'ONE LINE LOW @ A TIME
    IF KEYPRESS < 15 THEN MAP 'IF SWITCH IS PRESSED THEN
    NEXT
    GOTO DONEKEY
    MAP: KEYFLG = 1 ' Set Debounce flag
    KEYPRESS = NCD((~KEYPRESS) & 15)
    KEYPRESS = KEYPRESS + (JUNK * 4)
    LOOKUP KEYPRESS,[0,49,52,55,42,50,53,56,48,51,54,57,35],INKEY ' Map of the keypad legends
    LCDOUT $FE,$80
    PAUSEUS 100
    LCDOUT DEC2 KEYPRESS,"=",INKEY
    IF DEBOUNCE > 0 THEN
    INCDEC = 0 'DECREMENT DEBOUNCE COUNTER
    KEYFLG = 0 ' No key pressed, so Reset debounce flag
    KEYDOWN = 0 ' No key pressed, so Reset key Debounce flag
    DONEKEY:
    You could still use 1 Analog pin and few resistor.. kind of R-2R network.
    You could refer to tip #5,6 and #7 of the Microchip Tips and trick DS40040B
    http://ww1.microchip.com/downloads/e...doc/40040b.pdf
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. 4x4 keypad Help
    By aaliyah1 in forum mel PIC BASIC Pro
    Last Post: - 5th October 2010, 17:34
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. Another I2C Slave Routine Problem
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 06:50
  5. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
