How to use TMR command?
Results 1 to 6 of 6
    Jan 2006
    Slovenia EU
    Default How to use TMR command?
    Hello everybody!
    Can somebody help me to write a part of program, which could use TMR. I would like to control LED diode, which would blink in half a second (0,5 s) iterval. Between, the rest of a program should work undisturbed (it should not work with pauses or wait 0,5 s between commands). I use PIC18F452.
    START
    _
    -----> blink on
    <------blink off
    Thank you for your help.
    Samo
    Feb 2003
    Do a search for "instant Interrupts"
    There is an example in there that does exactly what you want.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Wink Simple, you said simple ???
    The simplest choice is to buy a blinking Led ...
    Jan 2006
    Slovenia EU
    hello,
    Blink led is not prper in my case. My LED has to work all the time in some cases.
    could you please paste a link with the same solution? (instant interrupt)
    regards
    Samo
    Quote Originally Posted by Samoele View Post
    regards
    Samo
    Could you please type the words instant interrupt into the search box?
  1. My code for TV remote and MIBAM for RGB control
    By idtat in forum Code Examples
    Last Post: - 12th January 2013, 21:52
  2. Easy HID Command -Response application
    By ptig185 in forum USB
    Last Post: - 22nd September 2010, 20:56
  3. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  4. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 19:57
  5. Interupts and Command string
    By Tissy in forum Serial
    Last Post: - 18th March 2006, 00:59
