Returning whole numbers for DS1820?
Results 1 to 7 of 7
    jessey's Avatar
    jessey Guest
    Default Thanks Darrel
    Hi Darrel,
    Are you suggesting that your code snip will work without using your "Temp_Convert" include file with my DS1820? I've tried it every which way with & without the include file and I can't seem to get it to work. Is there a sample on the list here that shows how its set up using a DS1820?
    Print_To_2nd_Line_Of_Lcd:' ,".",DEC2 Water_Temp,
         Sign = TempC.15
         TempC = ABS(TempC)
         TempC =(TempC>>1)*10 + (TempC.0 * 5)
       IF Sign then
         IF Its = Dark THEN
           IF Temp_Displayed = Fahrenheit then
             LCDOut $fe, $c0,1,"H2o = -",DEC Water_Temp / 10,".",DEC2 Water_Temp,0,"F"
           IF Temp_Displayed = Celsius then
             LCDOut $fe, $c0,1,"H2o = -",DEC Water_Temp / 10,".",DEC2 Water_Temp,0,"C"
         ELSE'if its light then show the print below
             LCDOut $fe, $c0,2,"H2o = -",DEC Water_Temp / 10,".",DEC2 Water_Temp,0,"F"
             LCDOut $fe, $c0,2,"H2o = -",DEC Water_Temp / 10,".",DEC2 Water_Temp,0,"C"
         IF Its = Dark THEN
             LCDOut $fe, $c0,1,"H2o=",DEC Water_Temp / 100,".",DEC2 Water_Temp,0, _
        "F ",DEC Lite_Level
        "C ",DEC Lite_Level
             LCDOut $fe, $c0,2,"H2o=",DEC Water_Temp / 100,".",DEC2 Water_Temp,0, _
        "F ",DEC Lite_Level
        "C ",DEC Lite_Level
    This is how I read the temperature:
    Update_Pond_Temperature:
     OWOut Sensor_Input, 1, [$CC, $44]    ' Start Water_Temp conversion
    waitloop:
     OWIn Sensor_Input, 4, [count_remain] ' Check for still busy converting
     IF count_remain = 0 THEN waitloop
     OWOut Sensor_Input, 1, [$CC, $BE]    ' Read the Water_Temp
     OWIn Sensor_Input, 0, [Water_Temp.LOWBYTE, Water_Temp.HIGHBYTE, _
                            Skip 4, count_remain, count_per_c]
        ' Calculate Water_Temp in degrees C to 2 decimal places
         Water_Temp = (((Water_Temp >> 1) * 100) - 25) _
                              + (((count_per_c - count_remain) * 100) / count_per_c)
      IF Temp_Displayed = Celsius then RETURN
     'IF the Temp_Displayed = Fahrenheit then Convert C to F before returning
      Water_Temp = (Water_Temp */ 461) + 3200
    When the temperature drops below 32 degrees F then it displays 556 instead of 31. I'd surely appreciate any further help you could provide.
    jessey
    Oops, I should have looked closer. Didn't see you're using the extended resolution. That routine was for .5 deg resolution.
    OK, so when the temp drops below 32°F, it means that the °C is going negative. And negative values can't be multiplied or divided in PBP. So the "extended Resolution" formula gives the wrong answer.
    Same problem with the Fahrenheit conversion, And the LCDOUT statements.
    Here's what I think should work...(untested)
    After reading the DS1820, change the second half of Update_Pond_Temperature: to this...
         Sign = Water_Temp.15
         Water_Temp = ((ABS(Water_Temp) >> 1) * 100)
         if Sign then Water_Temp = -Water_Temp
         Water_Temp = Water_Temp - 25 _
         Water_Temp = (ABS(Water_Temp) */ 461)
         Water_Temp = Water_Temp + 3200
    Then change the lcd routine to this...
       LCDOut $fe, $c0
       IF Its = Dark THEN
           LCDOUT 1
           LCDOUT 2
       LCDOut "H2o = "
       if Water_Temp.15 then LCDOut "-"
       Water_Temp = ABS(Water_Temp)
       LCDOut DEC Water_Temp / 100,".",DEC2 Water_Temp,0
           LCDOut "F "
           lcdout "C "
       IF Its <> Dark THEN
           lcdout DEC Lite_Level
    You don't need the Temp_Convert include file.
    HTH,
    jessey's Avatar
    jessey Guest
    Hi Darrel,
    Looks like I owe you some more beer, your code works excellent. My Pond Pump Controller circuit works great now. Really appreciated.
    jessey
    Woohoo! It's like Beer in the bank.
    Now I just need to find a local Branch office so I can make a withdrawl.
    __________________
    P.S. That's gotta be one COLD pond in B.C. in February.
  1. Replies: 4
    Last Post: - 15th April 2009, 01:54
  2. Numbers and Letters After PIC Number
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 11th October 2007, 09:13
  3. Working with 3 byte numbers
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 26th July 2007, 22:59
  4. Splitting numbers and recombining them(EEPROM Error)
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2007, 06:40
  5. Storing numbers for caller ID?
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 28th March 2005, 10:27
