Using LPT port dot matrix printer with PIC
Results 1 to 8 of 8
    Quote Originally Posted by sougata View Post
    I got some characters but nothing (ASCII) that I sent for printing.
    From that, it could be timing issue. Also try to send just one character followed by CR and LF. It should absolutely print the character and advance the paper.
    Italy
    See this link.
    http://www.phanderson.com/stamp/i2c/print1.html
    Verify the DIP switches of the printer.
    With some printers, with the DIP switches you can select the printer
    emulation mode. (Epson LQ emulation or IBM emulation).
    Best regards,
    Luciano
    Feb 2005
    Kolkata-India
    Question DIP switches found ??
    Hi Luciano,
    I found the DIP switches but no idea what they do, not in the manual too. It is a MSP 245.
    Ioannis I have tried making the timing high enouhg but results were same.
    I have found an article in the EPE mag July 2001 called PIC to Printer Interface by John Becker for printing on an EPSON printer. I have also found the epson documentation (escape sequences). I will give them a try and let you all know.
    BTW as far as grabbing data from the parallel port is concerned can anybody suggest me a software that monitors and records a parallel port data just like serial monitor.
    Thanks to everyone for responding.
    Sougata
    Oct 2006
    Cape Town SA
    Arrow
    There is also a marvelous site on all things serial and parallel at:
    http://www.lvr.com/parport.htm
    Italy
    Hi Sougata,
    The printer has an Hex Dump mode. This mode will show you
    exactly what codes the printer is receiving.
    (The printer will print each byte in HEX on paper).
    See the printer manual how to enable the HEX dump.
    To see if the selected emulation is a problem, boot
    the PC with DOS 6.22 and type:
    Copy myfile.txt > PRN
    (Put first 2 or 3 lines of text in the file myfile.txt).
    If you see the text of myfile.txt printed on paper you are fine.
    (The printer must be connected to LPT1 in order to use PRN).
    I was unable to downlaod a manual from the web site.
    http://www.tvs-e.in
    Try to phone them. (India).
    Contact:
    http://www.tvs-e.com/may12-05_contact.asp
    MSP 245 brochure:
    http://www.tvs-e.com/may12-05_downlo.../MSP%20245.pdf
    Note that you can install an optional serial port in this printer.
    Best regards,
    Luciano
    Mentor, Ohio
    Smile
    Hi sougata,
    Are you interested in the code for a 16F84 serial to parallel converter? If so, here it is:
    (This was on this forum back in January 2004)
    Serial 2 Paraller PRinter Converter
    ________________________________________
    HI! I don't know if this is what you want but give it a try
    THANKS HARRISON PHAM ,for the codding!
    'Serial to Parallel Printer Converter for Generic Printers
    'By: Harrison Pham March 30, 2003
    'PIC: 16F84 at 4mhz
    ' PIC Printer (DB25 Connector)
    ' Pin A1 Pin 16 (Init)
    ' Pin A0 Pin 1 (strobe)
    ' Pin B0 Pin 2
    ' Pin B1 Pin 3
    ' Pin B2 Pin 4
    ' Pin B3 Pin 5
    ' Pin B4 Pin 6
    ' Pin B5 Pin 7
    ' Pin B6 Pin 8
    ' Pin B7 Pin 9
    ' Pin 17 to gnd (Printer Select)
    ' *Pin 14 to gnd (if needed for autofeed feature)*
    ' Pin 18 to gnd (gnd)
    init con A1
    strobe con A0
    char var byte
    trisb = $00 'set portb to all outputs
    high init 'clear init line
    high strobe 'clear the strobe line
    portb = %11111111 'put all data lines high
    pause 1000 'pause for a second
    low init 'init the printer
    pause 500 'pause 500mill seconds to let printer init
    high init 'clear the line
    serin A2,N9600,[char] 'get characters with serial
    if char = 13 then 'if detected a cr then insert cr and lf
    PortB = 10 'lf
    low strobe 'tell printer to read in byte
    pauseus 200 'wait 200usec for printer to read in byte
    PortB = 13 'cr
    low strobe
    pauseus 200
    high strobe
    portb = char 'set portb to the char byte
    low strobe
    pauseus 200
    high strobe
    I'm sorry but I really don't know how to put this into one of those nice little windows. I think I need to find out how to do that. You might want to do a search for this post as there were some people who posted comments about the code.
    HTH!
    BobK
    I use a serial dot matrix printer on one of my projects. I use the DebugOut setup and it works great. I know you're using a parallel but thought I might be able to help!
    Feb 2005
    Kolkata-India
    Default Thanks Luciano and BobK
    First thanks Luciano for the effort. I am not trying to use that particular printer. I want to develop a hardcopy supported Datalogger. I have already tried the dos way. You would be glad to know that I have had some success. I would post the entire routine once it is complete. The other way round I needed a parallel to serial converter to take a look at the data that is being passed over the parallel port.
    BobK I am looking for the other way round but still your post is helpful. And if you are concerned about how to put a snippet into a code window then it is right down this (and every page) http://www.picbasic.co.uk/forum/misc.php?do=bbcode
    Sougata
  1. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 10:34
    Last Post: - 14th November 2008, 17:25
  3. Microcontroller with 2 way paging application problem
  4. 8 port Signal Loss Detector, possible to use a pic?
    Last Post: - 20th March 2006, 15:59
