SOUND command and variable array
Results 1 to 13 of 13
    SWITZERLAND (french speaking)
    Default SOUND command and variable array
    Hello,
    I'm (trying) playing sounds within an array.
    Unfortunately, I don't get it working.
    This is an extract of my (simplyfied) code.
    Vsnd var byte [4]
    Vsnd.0 = 121
    Vsnd.1 = 120
    Vsnd.2 = 119
    Vsnd.3 = 116
    FOR A = 0 to 3
       SOUND Speaker,[Vsnd.A,10]
    NEXT
    Any idea what I'm doing wrong?
    Roger
    Oct 2003
    holland
    try:
    FOR A = 0 to 3
    SOUND Speaker,[Vsnd(A),10]
    NEXT
    Tried this one already.
    Doesn't work either.
    This one doesn't work aswel:
    FOR A = 0 to 3
        SOUND Speaker,[Vsnd.0(A),100]
    NEXT
    Roger
    Oct 2003
    holland
    That is not what I typed.
    Did you give "speaker" a portnumber?
    Hi, Flotul
    What about Vsnd[A] instead ( Vsnd(A) or Vsnd.A ) ???
    Did you also check the tones are compatible with your speaker bandwidth ???
    just a thought ... for High audio frequencies.
    mat janssen,
    Don't worry: I copied/pasted your example "as it is" and it didn't work. I then posted another try I made. Sorry for the confusion.
    I tried with both brakets or parenthesis; never works....
    Yes, the sounds can be made correctly when not in this kind of referencing loop.
    Still searching.
    Roger
    Tried Brackets Here also ???
    Vsnd.0 = 121
    Vsnd.1 = 120
    Vsnd.2 = 119
    Vsnd.3 = 116
    Vsnd.0 is bit 0 of Byte Vsnd ( which is also different from Vsnd[A] !!! ) ... can't work properly here !!!
    Acetronics,
    I'm not sure to understand your remark.
    I tried this:
    and
    SOUND Speaker,[Vsnd.0(A),10]
    and
    SOUND Speaker,(Vsnd[A],10)
    and
    SOUND Speaker,(Vsnd.0[A],10)
    In fact, I get a sound but it is a much lower frequency than compared to when I play the sound like SOUND Speaker,[121,10].
    Roger
    Default ... no comment.
    Tried THIS ???
    Vsnd var byte [4]
    Vsnd[0] = 121
    Vsnd[1] = 120
    Vsnd[2] = 119
    Vsnd[3] = 116
    FOR A = 0 to 3
    SOUND Speaker,[Vsnd[A],10]
    NEXT A
    Acetronics,
    I tried this:
    and
    and
    and
    Do you have a cap on the output like the manual suggests? What kind of speaker are you driving? What's you OSC? Which PIC are you using?
    speaker var portb.1:a var byte:for a=0 to 255:sound speaker,[a,50]:next a
    or maybe:
    vsnd var byte[3]:vsnd[0]=10:vsnd[1]=30:vsnd[2]=75:vsnd[3]=120
    a var byte:for a=0 to 3:sound speaker,[vsnd[a],50]:next a
    Wink It works!!!
    Thank you ACETRONICS,
    You gave me the correct syntax.
    Just to make sure, I tried this that works too:
    Vsnd var byte [4]
    Vsnd(0) = 121
    Vsnd(1) = 120
    Vsnd(2) = 119
    Vsnd(3) = 116
    FOR A = 0 to 3
    NEXT A
    I personally would have appreciate to see this kind of example in the Compiler's manual instead of bothering you... I read it a few times, but without any clear example, it stayed unclear to me.
    Thanks a lot for your help.
    Roger
    Wink
    Hi, Flotul
    Just remember the same things must have EXACTLY the same name ...
    I do not know if brackets and parenthesis (?) really work the same manner ... but manual says "Brackets" !!! ... so let's write Brackets !!!
    no bad surprises involved ...
    Default Right!
    Thank you for pointing this out.
    Manual shows "brackets" and this is maybe why I wanted to try with parenthesis too
    Again, there is almost anything needed in the manual - same as in the data-sheets.
    Unfortunately, it is not always comprehensible for beginners like me.
    Roger
