Couldn't go to bed before i hooked up the pulse inputs.
When i hook up the pulse input to PortC.5 i get pulses on PortC.5 and not on PortC.4.
When i hook up the pulse input to PortC.4 i get counts on PortC.4 and PortC.5 as well.
The traces are paralell for awhile but if i was getting cross talk between traces i would think it would be in both directions. But its not. I can eliminate everything in the program that refers to PortC.4, put pulses into PortC.4 and still get pulses on PortC.5. There are no shorts between the traces or anything else on the board. It appears to be internal to the ports.
I did notice that these two ports do not have smitt triggers as most other inputs do. Can this have some thing to do with it.
Also there are internal pullups on these two inputs. I supposedly disabled them by setting UCFG.4 to 0 as well.
My pulse input is from a hall effect switch with a 1K pull up resistor.
Any thoughts????
RD
