16F648 and 115200 at 4 Mhz doesn't work...
Results 1 to 6 of 6
    Jan 2007
    Cus Darrel,
    OK, thanks for the answer. These typo is OK, I have just copy paste the parts of my code to get the idea to the others, what I am doing )))) So what you wrote is, that it is not possible to use this PIC at 4 Mhz with 115200. So you are suggesting to change tje crystal and to use 3.579 Mhz crystal, and in that case, it should work? I am now wondering, what will happen with PIC basic, because this is I think not supported. In manual for PIC basic is written that only supported values are 4, 8, 20 Mhz. Am I right? If not, what should be the OSC?
    OSC 3 is for 3.579mhz. (PBP manual page 170)
    All the timing (pauses etc.) should work fine.
