Can PicBasic support 56700 serial baud?
Results 1 to 10 of 10
    even @ 2400 baud, some PIC may don't work. Unless you want to waste your time to fine tune the internal osc (don't remind if you can do it with those 629 or 675), you should think of using a external crystal or a ceramic resonator.
    Jan 2007
    Well so far so good ( at least sending to the device) with just the little 12F675. I put the bit/byte patterns into eeprom and read them into bitstream output for each requested command to the device.
    I built a control switch pad this weekend using A/D on one pin.
    My next step is to include an encoded POT output device to control a second piece of equipment at the same time. I have two pins left..... oh boy !!
    These chips is fun!!
    Last Post: - 8th March 2010, 20:58
  2. Serial reading of binary at 75 baud
    By JasonMarsh in forum Serial
    Last Post: - 20th February 2008, 16:36
  3. PicBasic Pro CAN Support?
    By RMUTR in forum mel PIC BASIC Pro
    Last Post: - 18th November 2006, 00:19
  4. 110 Baud Serial Communications - Possible?
    Last Post: - 7th January 2006, 04:49
  5. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 02:17
