Hello folks...
One of the things that I get caught on every once in a while, MCLR being set to Reset.
If you look in the Chips instrution set, you can read whether a port is for I/O, PWM, AD, MCLR, or another purpose. You must tell it whether it is a digital or analog port. If you assign that port something that it is not, don't expect it to work!...
For example, the 12f675 has GPIO.3 is a INPUT pin, as well as a MCLR pin. Do not attempt to use GPIO.3 as a output pin.
When you program your chip, make sure you program your MCLR as a INPUT pin, not a RESET.
If you program the MCLR as a Input pin, your chip will power up by itself. If you program the MCLR as a RESET, you must use a resister and put some voltage to that MCLR pin to activate your chip.
As they say... A chip with no Spark, Looks pretty Dark.
Do not get caught in the trap of NOT checking to see if the pin is defaulted to INPUT on your programmer.
