The Microchip loader expects your config settings to match the settings in
the C18 loader template. If they're different, it throws up this error.
I've recompiled the C18 USB framework files myself, for use with the 18F2550
or 18F4550. Here's what I did in Main.c;
Note this assumes a 20MHz external xtal.
	#if   defined(__18F4550)
#pragma config PLLDIV=5,CPUDIV=OSC1_PLL2,USBDIV=2,FOSC=HSPLL_HS,FCMEN=OFF,IESO=OFF
#pragma config VREGEN=ON,CCP2MX=ON,WDT=OFF,WDTPS=32768,PBADEN=OFF,PWRT=OFF,MCLRE=ON
#pragma config LPT1OSC=OFF,BOR=ON,BORV=2,STVREN=ON,LVP=OFF,ICPRT=OFF,XINST=OFF,DEBUG=OFF
#pragma config WRTB=ON
#else
// For 18F2550 (NOTE: Be sure to swap linker files for the USB PIC being used)
#pragma config LPT1OSC=OFF,BOR=ON,BORV=2,STVREN=ON,LVP=OFF,XINST=OFF,DEBUG=OFF
#endif
 Just be sure to swap linker files before recompiling.
Then in my PBP 18F4550.INC file I placed the same config settings in it.
	  INCLUDE "P18F4550.INC"	; MPASM  Header
        CONFIG PLLDIV=5,CPUDIV=OSC1_PLL2,USBDIV=2,FOSC=HSPLL_HS,FCMEN=OFF,IESO=OFF
	CONFIG VREGEN=ON,CCP2MX=ON,WDT=OFF,WDTPS=32768,PBADEN=OFF,PWRT=OFF,MCLRE=ON
	CONFIG LPT1OSC=OFF,BOR=ON,BORV=2,STVREN=ON,LVP=OFF,ICPRT=OFF,XINST=OFF,DEBUG=OFF
	CONFIG WRTB=ON
 I made a few other modifications to the C18 loader firmware. Mainly just to
change the USB loader status LED's to a different port when using the
18F2550.
In io_cfg.h;
	/** L E D ***********************************************************/
#define mInitAllLEDs()      LATD &= 0xF0; TRISD &= 0xF0;
#define mLED_1              LATDbits.LATD0
#define mLED_2              LATDbits.LATD1
#define mLED_3              LATDbits.LATD2
#define mLED_4              LATDbits.LATD3
#else
#define mInitAllLEDs()      LATB &= 0xF0; TRISB &= 0xF0;
#define mLED_1              LATBbits.LATB0
#define mLED_2              LATBbits.LATB1
#define mLED_3              LATBbits.LATB2
#define mLED_4              LATBbits.LATB3
#endif
