Random number seed
Results 1 to 11 of 11
    Jan 2007
    Default Random number seed
    Thank you for all our help on my last post. It all really helped. To be honest, I finially just looked at the generated number and then based on its value fired off one of 5 sub routines. Here is the chunk of code i am using....Not very elegant but it works fine.
    Begin:
    Count = 0
    W0 = W0 + 1
    Peek PORTB, B2
    IF B2 = %10000000 Then Test
    GoTo Begin
    Test:
    Count = Count + 1
    IF Count = 6 Then Begin
    Random W0
    IF W0 < 13105 Then loop1
    IF W0 < 26210 Then loop2
    IF W0 < 39315 Then loop3
    IF W0 < 52420 Then loop4
    IF W0 <= 65525 Then loop5
    loop1:
    Toggle 0 'Turn on LED connected to RB0
    Pause 500 'Delay for .5 seconds
    Toggle 0 'Turn off LED connected to RB0
    GoTo TEST
    Now I am on to my latest issue. First off I am using Pic Basic (The low cost version.) I am trying to seed the random number generator with a changing opening amount. So each time I use the device, the initial random pattern changes.
    My queston is, the EEprom memory specifically location "0" should keep its value after the pick is powered down and then powered up again right??
    So all I have to do is set an additional counter and incrament the seed by setting memory loaction 0 to this counter.
    Jan 2006
    Istanbul
    Two questions:
    1. In your code above, you have the following.
    Lets take W0=10000 then all of these IF statements will be true and be executed. Or say W0=28000; in this case last three IF statements will be executed, etc...
    You should change it as follows.
    IF W0 < 13105 Then
    	loop1
    	IF W0 < 26210 Then
    		loop2
    		IF W0 < 39315 Then
    			loop3
    			IF W0 < 52420 Then
    				loop4
    OR use a select case, it would make it easier to follow the logic.
    2. Forget this one.
    Post
    There was a thread about random numbers, here ... sometimes ago.
    Conclusion was Microchip offers the best routine ( assembler ... yes ! ) in its applications.
    Default Sorry to jump in.....
    Why is that?
    If W0=10000 the first IF statement tests true and the program jumps to the Loop1 routine which is executed. At the end of Loop1 the program jumps to Test where a new RANDOM is executed and assigned to W0. Lets say it's 28000 as in you example. The third statement tests true and the program jumps to Loop3, executes it and then starts over with another RANDOM. At least that's how I read it.
    HTH
    /Henrik Olsson.
    Jan 2006
    Istanbul
    You seem to be having it correct Henrik.
    Jan 2007
    Actually the if statements work fine, but I like adding the "Else" statements and "EndIf"s to clean up the code (Thank you Sazer). and comments to clarify the logic behind my code. My real issue is the way the code is now, my code always provides the same sequence of numbers on start up. I need it to be different each time at startup as well as any other time it basically is supposed to randomly flash 1 of 5 different LEDs - 5 times and then stop and wait for B.7 to go high and then star again. So how can I randomly add a seed to the very first iteration of this process. I read some where that you can pull a value from TMRO, so it will give you an initial seed of 0 to 255. Any thoughts?
    Hi, Kwelna
    Just keep the last value before switching off in EEPROM ... as a new seed !!!
    Jan 2007
    Default Random seed
    Duh!!! So simple I never would have thought of it.........well maybe in a week or two.... I am alwqys looking for a more complicated method. that is what happens when you get old!
    Thanks again
    Kevin
    Quote Originally Posted by kwelna
    Imagine when you'll be as old as i am
    You could still use an hardware solution... count pulses at the output of a white (even pink) noise generator... now it's going to be really random. Always a long debate around this....
    Talking Stone age survivors ???
    Hi, Steve
    You were talking about the MM 5837 ... I suppose ???
    The only one corresponding to your age LOL !!!
    Hi, Kevin
    << I am alwqys looking for a more complicated method. that is what happens when you get old! >>
    Here, you're only talking about yourself ...
    Ah, Will you have a look here ???
    http://www.manhattancontrols.com/for...932b79b20ee1c5
    Hi, Steve
    LMAO! well could also be a simple op-amp (maybe dual), cmos gate etc etc. no need for a dedicated IC. Maybe PBP SOUND could do the job.
  1. Random Numbers
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 18th December 2008, 08:47
  2. Random seed using the ds1307 RTC
    By rookie11 in forum General
    Last Post: - 25th November 2007, 20:31
  3. Working with the random number generator
    By kwelna in forum mel PIC BASIC
    Last Post: - 16th January 2007, 17:50
  4. Random number results
    By bartman in forum mel PIC BASIC
    Last Post: - 9th March 2005, 17:39
  5. more random number questions
    Last Post: - 14th November 2004, 17:55
