Angle measurement for balancing robot.
Results 1 to 40 of 53
    Italy
    Hi Henrik,
    Why not work first on a simplified version of
    the self-balancing robot?
    Version 1: (For flat surfaces only / indoor).
    Use a Sharp infrared sensors to measure the distance to
    the floor and uses that information to deduce tilt angle.
    Version 2: (For flat and inclined surfaces).
    Encoders + rate gyro
    Try the second version of the self-balancing robot only when
    version one works as expected. I am sure that you will
    able to re-use part of the code and experience developed
    during the realization of the first version.
    Best regards,
    Luciano
    Luciano,
    Absolutely!! 2 Sharp GP2D120 ordered from ARRobotics, hopefully they'll be here within a week or so. If (when) I get that to work it will boost my motivation even further.
    Thanks!
    /Henrik Olsson.
    Jan 2007
    Muenchen, Germany
    Wink balancing two-wheel robot using accelerometer or rate gyro
    Hi Henrik,
    I am also working on a balancing robot. My platform is an ATMEGA16 with L293D motor controller ICs and I am using a two-axis accelerometer board built with Freescale MMA2260DR2 for x-axis and MMA1260DR2 for z-axis with a bandwidth of 50Hz, which should be fast enough for a pure accelerometer solution. The robot's mechanical structure is built with Fischertechnik components. I also use a rate gyro CRS03-02 by silicon sensors (bandwidth 10 Hz, which could be a little too slow).
    I also asked myself whether it could be possible to use only the accelerometer alone or the rate gyro alone. To solve the problem of the acceleration of the robot influencing the measurement values of the two-axis accelerometer I would like to suggest the following to you:
    First of all I would recommend to use both readings of the two-axis accelerometer. The accelerometer should be placed in the height of the motors. If you use the x-axis in direction of the robots acceleration and the z-axis in the direction to the sky or ground (starting initially without tilt), both the tilt and the acceleration can be calculated from the data using trigonometric relations and solving a squared equation. I used the drawing in the paper of Joe Le Pendulum for reference, see attached file Tilt_Angle.doc or their paper on the web, Figure 5.
    Then the forward (or backward) acceleration a of the robot can be calculated to:
    a= +- SqareRoot( Square(x) + Square(z) - 1)
    + for the case a>0
    - for the case a<0
    and
    tilt=arcsin((x-z*SquareRoot(Square(x)+Square(z)-1))/(Square(x)+Square(z)))
    # for the case a>0
    tilt=arcsin((x+z*SquareRoot(Square(x)+Square(z)-1))/(Square(x)+Square(z)))
    # for the case a<0
    tilt=arcsin(x)
    # for the case a=0
    All values are normalized to the earth's acceleration g (g=1).
    The remaining unknown figure is the sign or direction of the acceleration a to get the correct result for the tilt. This could be derived from the motor control comparing the motor power during the last two control steps before this measurement.
    For the motor control it is then essential to use in addition to the tilt also the tilt change rate (for a PD regulation) by comparing the last two tilt values (differentiating), because if you only use the tilt itself, the reaction of the motors will be too slow.
    If you only want to use the rate gyro alone (as was done for Joe Le Pendulum), then you need a way to compensate for the gyro's drift. A simple way of doing this could be to work with a running average for the offset. Make a reference measurement of the offset as a starting point and keep the robot in an upright position for a short time after releasing the reset button. Then update the offset with a weighted value of the rate measurement, such as:
    offset_new= offset*(999/1000)+ rate/1000
    for every new measurement of the rate. The weighting should be adapted to the timing period of your measurement updates. By this the drift of the gyro could be compensated. I am working on this tuning at the moment. Assuming a measurement timing period of 10ms (100Hz), the above equation would correspond to a low pass filter with 100Hz/1000=0,1 Hz filtering the dc component of the measurement signal to be used for the offset.
    All this I am writing here is still in an experimental state and are thoughts I developed during my research over the last weeks. I hope you can make use of these ideas. If so, please let me know. My own robot is not yet perfectly balancing, I am tuning the PD regulation constants and the offset filtering at the moment based on the pure gyro rate approach. Next step I will do then is use the pure accelerometer approach.
    Kind regards, uffi.
    Thumbs up
    Uffi,
    That is some nice info, THANK YOU! I will definetly investigate and/or try both methods and will post any results in this thread. Please let me know how you are progressing as well!
    Thanks again!
    /Henrik Olsson.
    Jan 2007
    Muenchen, Germany
    Wink parameter.h
    Henrik,
    one question regarding your posted attachment "kalman.zip". In the source "tilt.c" a header file "parameter.h" is linked, which is not included in your file "kalman.zip". Also I could not find these files in the latest releases of the autopilot UAV command and control project (version 2.5, 2.4 or 2.3). Which project at sourceforge has developed these files?
    Can you post also the file parameter.h?
    Thanks in advance, uffi.
    Hi Uffi,
    I think that the original files came from the UAV project on sourceforge. Anyway the zipped archive of the complete file-set as found on the Nuts & Volts FTP-site is 345k and the max attachement size allowed here is 200k. So I'll attach the Parameter.h only (change file extension from .txt) and if you want the rest I can e-mail it to you directly or you can get them from the N&V FTP-site. Here: http://www.nutsvolts.com/~downloads/B-Bot.zip
    Are you saying that you are working on converting the routines to PBP? If you do and want to share it I will owe you big time!
    I just got my two SHARP GP2D120 in today so I will have a go at using them first. Then I'll revisit the gyro/accellerometer approach.
    Hope to here from you!
    /Henrik Olsson.
    Default Lots of energy spent
    Thinking about balancing robots, a lot of energy is spent to do this, both electrical energy and your energy. I would suggest using large wheels and ballasting the robot below the axle to lower the C/G. Perhaps the batteries could go there. then install one of the gyros sold for R/C helicopters to help stabalize the bot. I think then your code for the motors would be less critical, and robot would would make you smile sooner (even if the ballast is inadequate to allow it to stand without controller operating, it should help).
  1. Replies: 0
    Last Post: - 2nd February 2009, 23:23
  2. PIC16F877A for application in mobile robot...
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 14:47
  3. Need Help - Line Tracer Robot
    By pidot in forum mel PIC BASIC Pro
    Last Post: - 10th August 2007, 14:58
  4. IR for robot on 16F877A
    By Samuel in forum mel PIC BASIC Pro
    Last Post: - 9th April 2005, 20:57
  5. Line tracer robot
    Last Post: - 30th January 2005, 15:36
