Using Pic as a digital clock/timer. How accurate?
Results 1 to 19 of 19
Threaded View
  1. #8
    Wink Have a happy new year, Rocky !!!
    Hi, Rocky
    I just built Thermo-baro-clock with a MS5534 sensor.( 16F876 ) the clock is driven by a 32.7... khz "clock crystal" connected to RC0,RC1 pins and using TMR1 ovf interrupt.
    The only way to adjust reading is to trim the TMR1 preset ( 32768 ...in theory ). an adjustable capacitor parallelled to one of the xtal load caps could also help a bit.
    Possible also to use two pushbuttons to inc/dec the TMR preset value, you then store in the EEPROM ... but do not forget to limit the trim range !!!
    But as always ... no simple automatic trimming.
    Absolute references will always be our main headaches ... cause there's none naturally existing !!!
    best regards
  1. Digital clock thermometer Calendar PIC 16F628
    By valdirdf in forum Code Examples
    Last Post: - 31st May 2009, 01:52
  2. PIC 18f4680 DIGITAL INPUTS
    By MegaADY in forum mel PIC BASIC Pro
    Last Post: - 30th July 2008, 07:34
  3. Digital Holter with PIC ?!
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 28th November 2007, 10:37
  4. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 20:42
