ic2 write
Results 1 to 5 of 5
Thread: ic2 write
    Smile ic2 write
    trying to set up a clock program and cant find info on the "control" part of the command.
    very limited info in pbp examples show $a0 used a program i found uses 0xa2
    which gives a error message if i use any help here and where can i find
    additional information on this
    thanks for all your help
    Default more info
    new i would have more questions
    what is the number format 0x
    does anybody have a clock program for the pbp
    Mentor, Ohio
    Smile
    Use the search feature. There have been several clock programs. 2 were posted in the Code Examples that use the timers in the PIC, Melanie's Olympic Timer, and there have been a few posts on using the RTC DS1337.
    BobK
    May 2006
    Del Rio, TX, USA
    $ and 0x are two different annotations for HEX. So,
    $A0 = 0xA0
    PBP recognizes $, not 0x annotation.
    Default thanks
    simple once you know the answer
    thanks again
  1. WRITE: One more PBP 2.60 Surprise ...
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 26th August 2009, 10:10
  2. Replies: 5
    Last Post: - 29th May 2008, 19:03
  3. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  4. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 18:27
  5. Storing Strings using the Write command
    By BobP in forum mel PIC BASIC Pro
    Last Post: - 1st November 2005, 12:31
