I have used several time the M33033 and the M33035 from Motorola. It very simple to conect these with a pic.
The only connection are.
+5v or gnd for the direction
5v for enable input
0 to 5Volts for speed.
5v for enable input
thnx for all of you
what i understand from you guys
that i must generate 1 - 2 ms PPM signal to the ESC
to generate the signal i must build a servo pulser
so which one better this http://www.uoguelph.ca/~antoon/gadgets/servo3.gif
or the one in the attach?
Hi Al
Mine ...( The second !!! ) works fine and is simple to realize ...
but all "555 " designs are to be used without fear !!!
hey
Acetronics i know you get bored from me but i swear its the last question
after i build the servo pulser
i should conect the red wire one the ESC to the + wire one the servo pulser
and the brown to - and the orange to the signal and it(the motor) will work without a receiver right?
