Adcon
Results 1 to 8 of 8
Thread: Adcon
    Jun 2006
    Default Adcon
    Hi
    I want to use the command ADCIN but my pro compiler brings errors with ADCON. Can Anybody tell me whats wrong
    Itīs an Error in the pbppic14.lib. mostly the error is "undefinded Symbol"
    can anybody help me
    Martin
    Oct 2003
    holland
    Show us your code please !
    Jun 2006
    Default Code
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 2
    DEFINE ADC_SAMPLEUS 100
    PORTA = 5
    TRISA = $85
    PORTB = 6
    TRISB = $86
    POKE TRISA, %11111111
    POKE TRISB, %00000000
    W0 var byte
    ADCON1 = 2 'This line is not working !!!!!!!!!
    ADCIN 0, W0 'This line is not working, too
    Martin
    Default Which PIC?
    First you set TRISA to $85 and then overwrite with 255 using the POKE command, same goes for TRISB, seems strange to me but is probably not related to your problem.
    You didn't say what PIC you are using??
    BTW, even though they still work it is recomended to not use the PEEK/POKE commands.
    /Henrik Olsson.
    Jun 2006
    Default Pic
    Iīm using the pic16f627a. The problem is that the compiler does not racognize the command ADCON. There must be something to include or to register.
    martin
    Hangover, Germany
    Exclamation
    The PIC16F627A has no ADC, it has no ADCON1-register and ADCON is no command.
    Jun 2006
    ah ok....is there anotherway to meassure voltage ??
    thanks martin
    Oct 2003
    holland
    To use a 16F819 or a 16F873(6)(a).
    Or if you want to do something under or above an sertain input voltage then you can use the 16F627a with its internal comperators.
  1. What is ADCON?
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 6th January 2007, 00:55
  2. adcon problems with adcin
    Last Post: - 3rd January 2007, 23:15
  3. 16F818 ADCON question
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 1st February 2006, 11:50
  4. ADCON Explanation
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 11th December 2005, 20:08
  5. ADCON does not compile 16F628
    By mslaney in forum mel PIC BASIC Pro
    Last Post: - 14th January 2005, 16:43
