Switch / Potentiometer
Results 1 to 13 of 13
    Italy
    Hi Keith,
    The bloody theme is still around! Enjoy!
    http://www.teamknightrider.com/music/krtheme.wav
    Best regards,
    Luciano
    P.S. Before you click the above link, cover the PC keyboard with plastic wrap.
    May 2006
    Del Rio, TX, USA
    Default Another possibility
    If your not commited to a POT, you could use an encoder with a switch to do essentially the same thing (but you would not have the "stops" that a POT has). I love to use these for input devices. One knob is all you need! However, if you have never used an encoder with a PIC there is a bit of learning curve to get them working well. Worth the effort, though (IMO), and lots of resources on the forum/net to learn from.
    Here are some from Digi-Key. More options to choose from on other pages as well.
    SteveB
    Ive concidered using an encoder but doesnt that mean I'll need more than one pin for the input? Right now my pin count is prety much maxed out
    As far as using an 3914/5/6 display, they are only for 10segment LED's.
    Furthermore, This 12segment display is over used in the dash, its just everywhere... one of the other applications Im working on is the fuel consumption displays which takes the Fuel level and an odometer pulse and computes MPG and distance left... which obviously would require more than a display driver. Plus with the PIC you get the bonus of little sound effects.
    So while Im not opposed to an encoder I have no idea how they work... have always assumed they output a 4bit BCD number... As it stands now the only pin I have left for input is portA.5
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by bearpawz View Post
    ...doesnt that mean I'll need more than one pin for the input? Right now my pin count is prety much maxed out
    Yes, for the Switch/Encoder combination you would need 3 Pins. 2 for the encoder (preferable on a pin with an interrupt on change feature) and one for the switch. There are different types of encoders, this probable being the most basic.
    Here is a descent explaination, but it sounds like the POT will be best, given the pin count issue.
    SteveB
  1. counting switch events beginner
    By mrpete in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 17:08
  2. Newbie - 16F628A and switch latching
    Last Post: - 19th May 2006, 03:35
  3. Potentiometer with indexing.
    By muddy0409 in forum General
    Last Post: - 1st January 2006, 20:41
  4. Switch Sequence
    Last Post: - 13th February 2005, 21:36
  5. Switch Polling vs Interrupts
    By eric blair in forum General
    Last Post: - 17th October 2003, 10:38
