SERIN AND SEROUT PROBELM USING 16f690 PIC
Results 1 to 14 of 14
    Jan 2007
    what sets the valid in Rx is the dgood(pin) from transmitter so whenever the key pressed, the dgood become low and it is connected through wire to the valid pin in receiver so it will go out from the wait loop and display...
    the thing is all goes well accept the value inside the num(register) is 0 when i display..is the way i use the serin and serout is correct?...do u have any suggestion..thanx very much
    Quote Originally Posted by Charles View Post
    Ok, back to you again, what sets valid = 1 or valid = 0?
    Jan 2007
    in the transmitter part
    u see the dgood pin..it is connected to valid pin in receiver...
    therefore whenever i press the keypad, dgood become low which indicate valid =0...therefore it will goes out from the wait loop (in the receiver part) and display the number inside
    Default Schematic anyone?
    Hey Charles, you suppose we could see a schematic? It sort of looks as if you want to send serial data from one pic to the other, hence skimasks question, but if you have everything all hardwired together, then we need to see how.
    JS
    Jan 2007
    dgood (portB.4) from PIC1 i connect it to valid(portB.6) from PIC2...sorry there is a mistype in the code it should be valid var portB.6 not valid var byte...then otupin(portB.7) from PIC1 is connected to keyinput(portB.5) from PIC2)/....yup i'm trying to send data serially from pic1 to pic2...any suggestion?thanx very much...
    best regards
    Charles
    Yes, but on the receiver side, valid is a BYTE, not a Pin.
    So back to skimask's question,
    "What sets the valid in the RX code?"
    But he's only got TWO WEEKS!!!! AAAaaaaaaaaaaaaa.............
    Easy skimask, Down boy, Down!
    Let me take this one ...
    I'm always skeptical when someone Cut&Pastes their entire program into a Post.
    And, the one thing that points out a definate cause of the described problem suddenly turns into a "typo".
    In the middle of a Cut&Paste? Come on!
    See, I can do it too.
    Ok well, my advice is to dump the keypad routine, and use this...
    Matrix Keypad routine (mister_e)
    http://www.picbasic.co.uk/forum/showthread.php?t=3250
    Then take a look here...
    How to make your own PIC network (mister_e)
    http://www.picbasic.co.uk/forum/showthread.php?p=5708
    Not exactly what you are doing, but the concepts are the same. Just 2 PIC's instead of many.
    Jan 2007
    The output my program right now when i display on the lcd is
    ENTER POLARITY
    1)+ 2)- 0(this zero should be number that is pressed on the keypad)
    OK skimask,
    You have my permission.
    Pfft!
  1. SERIN and SEROUT
    By CumQuaT in forum mel PIC BASIC
    Last Post: - 3rd September 2009, 00:17
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
    Last Post: - 13th December 2008, 17:11
  4. 16f690 crashes
    By Lincoln S. in forum Serial
    Last Post: - 26th November 2008, 08:32
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
