'*/' operator
Results 1 to 3 of 3
Thread: '*/' operator
    May 2006
    Default '*/' operator
    Hello I was wondering if someone can better explain what is happening when using the '*/' command. I had posted some months ago asking for help in converting a 10 bit analog to digital number into a value of 0 to 5 to display it on an LCD. Here is the code that someone posted and it works perfectly fine.
    I am performing A to D on analog channel 11 on a PIC16F690
    READ_A_D_AN11: 'used for adjusting set pts
    ADCON0 = %11101101 'right justified, using Vref, AD on Channel 11
    PAUSEUS 50 ' wait 50 microsec
    ADCIN 11, AD_AN11_VALUE ' read channel 11 to AD_AN11_VALUE
    AD_AN11_VOLT = (AD_AN11_VALUE */ 5000) >> 2
    Code for displaying it on an LCD.
    DISPLAY_SENSOR_VALUE:
    GOSUB CLEAR_LCD
    GOSUB READ_A_D_AN11
    LCDOUT "Rotary Voltage"
    LCDOUT $FE, $C0, "Sensor ", DEC (AD_AN11_volt/1000) ,".", DEC3 AD_AN11_VOLT ," VDC"
    This works perfectly fine and displays a value of with 3 decimal places.
    What I am attempting to do is use a potentiometer to act as a trigger for another part of a circuit. I can set the voltage points in software to act as trip points. What I would like to do is create a window in which the trigger will occur. I was simply going to have another routine that would be adjustable from 10 to 250, which I would like to represent 0.010V t0 0.250V. The problem is that I was going to just take the number 10 to 250 and subract that from my A to D conversion value but that does not give me the true representation of what I need to adjust my window by.
    I would like to some how convert backwards from what I did to get my range from 0 to 5 V from the A to D value of 0 to 1023. I would like to take 0.01 to 0.250V and convert this to a proportional value to subtract from my A to D value.
    If I have not confused everyone and someone has any ideas I would love to hear them. Thanks for your help.
    */ is the MidWord multiplier.
    When you multiply 2 16-bit values together, you'll get up to a 32-bit result (4 bytes). The Midword, is the 2 bytes in the middle.
    For instance, let's say you have an A/D value of 600, and you multiply it times 5000, that gives you 3,000,000. And if you express that in Hexadecimal, it looks like ...
    002D:C6C0
    The MidWord is 2DC6, or 11,718.
    That's the same as (600 * 5000) / 256. The /256 is implied, and happens without the extra time required to do a division. So, it can be allot faster than using DIV32.
    The rest of the formula is, >> 2, or shiftright 2 places. Which is the same as /4. Since the result has already been divided by 256, /4 makes the total divisor equal to 1024 (256*4). And, the result will be 2,929, which represents 2.929 Volts input to the ADC.
    So, the whole formula is really just (600 * 5000) / 1024. But in a way that PBP can handle it with 16-bit numbers.<hr>
    OK, so how to go the other direction...
    You'll need the integer numbers (10 to 250) I'll call it Offset. Then just do the reverse formula.
    AD_Cal = (Offset * 1024) / 5000
    This one doesn't fit in with the */ operator, so you'll need to use DIV32.
    Offset = 250          ; 0.250V - Must be a WORD Var
    AD_Cal = Offset * 1024
    AD_Cal = DIV32 5000
    This gives a result of 51, which can then be added or subtracted from the AD result as necessary.
    HTH,
    Mar 2005
    Iowa, USA
    Default supplement
    To supplement Darrel's example/description, I'd suggest looking HERE for some good examples.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
  1. ISD17240 on PIC16F88
    By drewcog in forum mel PIC BASIC Pro
    Last Post: - 17th December 2008, 21:07
  2. what is objective of this operator "*/" ?
    By iugmoh in forum mel PIC BASIC Pro
    Last Post: - 17th April 2008, 03:43
  3. Exponential Operator
    By andrewroz in forum mel PIC BASIC Pro
    Last Post: - 31st October 2007, 09:00
  4. Help to Get The highest value in Array
    By jetpr in forum mel PIC BASIC Pro
    Last Post: - 11th August 2005, 12:09
  5. math operator LOG
    By Eyal in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2004, 00:45
