data with wordvar?
Results 1 to 11 of 11
    Jul 2006
    Default data with wordvar?
    Hello
    Can the DATA command handle word variable?
    like this
    Data @1, $1DF4, $FAFD, $AB13, $3FC3
    For i = 1 to 4
    read i,wordvar
    'do anything
    next i
    Is this correct?
    Best Regards
    Pedro
    Quote Originally Posted by Pedro Santos View Post
    Hello
    like this
    For i = 1 to 4
    read i,wordvar
    'do anything
    next i
    Is this correct?
    Best Regards
    Pedro
    Data @0, $1DF4, $FAFD, $AB13, $3FC3
    For i = 0 to 3
    read i , wordvar.lowbyte
    read i , workvar.highbyte
    'do anything
    next i
    1st time thru wordvar = $1DF4
    2nd time thru wordvar = $FAFD
    3rd time thru wordvar = $AB13
    4th time thru wordvar = $3FC3
    It's all right there in your handy PicBasicPro manual that you got when you bought PicBasicPro, page 53 and page 123.
    Mine's green, what color is yours?
    Mine's Olive.
    And yup, right there on page 53 is all about the DATA statement.
    And in it, it says ...
    "Only the least significant byte of numeric values are stored unless the WORD modifier is used"
    Therefore:
    Data @1, WORD $1DF4, WORD $FAFD, WORD $AB13, WORD $3FC3
    Jul 2006
    Hello Darrel
    data @1, word $E276, word $E183, word $8001, word $EF90
    and how can i read the variavle?
    so?
    for i = 1 to 4
    read i, wordvar
    ''do anything
    next i
    is that correct?
    Pedro
    Hello Darrel
    so?
    for i = 1 to 4
    read i, wordvar
    ''do anything
    next i
    is that correct?
    Pedro
    Did you even see post #2 above?
    Well, like everthing else, there's probably 100 different ways to go about it. And the best way depends on how your program needs to use it.
    But the biggest thing to remember is that you can only READ 1 byte at a time. So, to read a WORD value must be done in 2 operations.
    READ  1, wordvar.LowByte
    READ  2, wordvar.HighByte
    If you wanted to read the data into an array of WORDS, you could do this...
    ArraySize   CON 4
    WordArray   VAR WORD[ArraySize]
    Ptr         VAR BYTE
    DataStart   VAR BYTE
    DataStart = 1
    For Ptr = 0 to (ArraySize * 2) -1
        READ  DataStart + Ptr, WordArray.LowByte(Ptr)
    Next Ptr
    If you just want to read individual words, then you'll need to know where they are located in EEPROM. You could just count bytes in the data and use the starting address as the location for the READ. But as the program changes, the data might change too, and all those locations you counted fly out the window.
    So the easiest way to deal with individual Locations is to give them names in the DATA statement. Then when things change, the pointers to the data change too.
    Calibration  DATA @1, WORD $1DF4
    Offset       DATA WORD $FAFD
    Something    DATA WORD $AB13
    Another      DATA WORD $3FC3
    READ  Something, wordvar.LowByte
    READ  Something + 1, wordvar.HighByte
    ; returns $AB13
    READ  Calibration, wordvar.LowByte
    READ  Calibration + 1, wordvar.HighByte
    ; returns $1DF4
    Well, that's 3 possibles, at least 97 more available.
    HTH,
    Jul 2006
    Thank's Darrel for your help
    Pedro
    Lightbulb
    Oh Yeah, forgot to mention that you might find this usefull as well.
    EEPROM Variables (EE_Vars.pbp)
    http://www.picbasic.co.uk/forum/showthread.php?t=2444
    And man oh man, did I screw up my example above in post #2... If you'll excuse me for a moment, I'm going to go outside and kick my own a$$...
    Could you get someone to take a picture of that?
    Just thought it might Brighten somebody's Day.
    I think I'm allowed that one. Maybe not.
    How's this one for ya?
    And besides, I get to drive from here to Tucson tomorrow morning... 58 miles from Canada to 58 miles from Mexico, one end of the country to the other.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
