Can i use timer1 as a counter while using it by HPWM
Results 1 to 3 of 3
    Actually, the datasheet (16F877), table 8-1 as well as figure 8-3 shows that the PWM generation uses TMR2, not TMR1. It DOES use the CPP1 module though but feel free to use TMR1 as you wish. You can use CPP1 for HPWM and CCP2 for capture/compare if that's what you want.
    Note, this MAY be different on other PIC's but since you didn't say which one you're using a took the F877 as an example.
    Hope it helps.
    /Henrik Olsson.
    Dec 2006
    Default Many thanks
    Many thanks ... It seems that i was confused by the define
    statement explained in the pic basic pro compiler manual
    which showed defines to choose either timer1 or 2 for channel 2 or 3 in the pic17fxx series while i am using pic16f877a ... Many thanks for your concern .
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Replies: 14
    Last Post: - 26th September 2007, 06:41
  3. Microcontroller with 2 way paging application problem
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
