warning message
Results 1 to 3 of 3
Thread: warning message
    pic beginner's Avatar
    pic beginner Guest
    Default warning message
    Hi anyone
    I wrote a program in microcode studio IDE.
    When I compiled it , below message was appeared:
    '...[102] code crosses boundary @ 800h "
    whats the meaning of this warning and what must I do?
    Thank alot
    This is a perfect FAQ example - which is exactly the section where the answer has just ended up...
    ivanenev's Avatar
    ivanenev Guest
    I also have a question concerning microcode studio and warning message.
    Compiling a program, PBP gives a warning saying:
    "Warning[202]...\rt8166~1.mac 661: Argument out of range. Least significant bits used."
    I think it appears when I fill an array with the following code:
    array VAR BYTE[8]
    i VAR BYTE
    Value VAR BYTE
    Counter VAR BYTE
    Data1 DATA "MyData",0
    ' fill an array with "MyData"
    LOOKUP i-1,[Data1],Counter
    fill:
    READ Counter,Value
    IF Value != 0 THEN 'Make sure it's not 0
    array[Counter]=Value
    Counter = Counter + 1
    GOSUB fill
    ' do something
    What does it mean?
    Thank you.
    Ivan
  1. PIC16F690 PBP boundary crossing warning message
    Last Post: - 9th May 2008, 12:17
  2. Advice please - Warning message
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2007, 14:20
  3. Micro Code Studio - Warning message
    Last Post: - 17th November 2006, 22:17
  4. MicroCode Studio Boundary Warning Message
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 16th March 2006, 10:13
  5. Message String Table using Readcode
    By mytekcontrols in forum Code Examples
    Last Post: - 11th July 2005, 00:17
