Originally Posted by
champion
Skimask, I don't think that you have read about my problem. I believe I said before that I need a resolution of at least 360*60=21600 pulses per revolution. Okay, try and find an encoder that has more than 8192 ppr for less than $100. You can't. Then I guess you could use a quadrature decoder along with the encoder to increase the resolution. There you have 8192*4=32768 ppr. That's enough resolution. So what is it that you think that is physically impossible? Didn't you read above that I was using a decoder? And why do you keep talking about missing pulses or any need for a higher frequency oscillator? I think you're probably a smart guy so that's why I must assume that you are simply not reading the entire thread carefully. Go back and read through all of the posts before you make any more comments. k?
