problem with 16f877 and display
Results 1 to 5 of 5
    Jan 2007
    Default problem with 16f877 and display
    I'm getting trouble with a HD44780 compatible lcd display
    and a pic16f877a that doesn't work togheter!
    Display it's ok when connected to another circuit made around a PIC16f628
    Data and control signals are on port "A"
    data are from A0 to A3
    RS is on A5
    E is on A4
    at the top of the program i put the following defines
    (In the program there aren't other assignment for PORT A)
    DEFINE LCD_DREG PORTA 'LCD data port
    DEFINE LCD_DBIT 4 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTA 'LCD register select port
    DEFINE LCD_RSBIT 5 'LCD register select bit
    DEFINE LCD_EREG PORTA 'LCD enable port
    DEFINE LCD_EBIT 4 'LCD enable bit
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 'Command delay time in us
    DEFINE LCD_DATAUS 50 'Data delay time in us
    then the first output on LCD is simply made using:
    PAUSE 1000
    LCDOUT $FE,1, "TEST LCD"
    result: no output on LCD
    what's wrong !?!?!?!?
    Oct 2003
    holland
    When this is all you programmed, then you forgot sommething.
    When you do nothing else then this in your programm, the A port is complete an analog port. (see datasheet)
    Try
    ADCON1 = 7
    maybe it helps!
    Jan 2007
    Damn!
    i forgot it wasting the time checking in the wrong way.....
    thanks a lot Mat...
    Default Port A
    Hi Steve,
    PortA.4 has open drain output, I believe will require external pullup resistor.
    JS
    Jan 2007
    Problem solved.... it work!!!
    first i forgot to define ADCON1 = 7 and the pull-up resistor
    on A4 (open drain) (thanks to Mat and Joe)
    Then another error found was on
    DEFINE LCD_DBIT 4
    instead of
    DEFINE LCD_DBIT 0
    Thanks for help......
  1. LCD problem with 16F877
    By alexx_57 in forum General
    Last Post: - 25th July 2007, 13:47
  2. need help on display problem
    By sixty9sandals in forum mel PIC BASIC Pro
    Last Post: - 30th March 2007, 03:57
  3. Display Vref 16f877
    By tico in forum mel PIC BASIC Pro
    Last Post: - 14th January 2007, 11:34
  4. ISD4003 & 16F877 Interface
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 26th December 2006, 17:50
  5. Serial from 16F877 to VB
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 20th March 2005, 23:33
