Trouble with Optrex 4x20 LCD module
Results 1 to 8 of 8
    Jul 2006
    USA
    By the way, I use
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 100
    for the LCD timing. If you go faster on the data, such as 50 us, then
    the Optrex 4-line display will be garbled.
    Quote Originally Posted by Brock View Post
    By the way, I use
    Most likely, you can reduce that commandus down quite a bit, like I said, maybe 200.
    The dataus at 100, sounds good enough. Maybe throw another cap across the power/ground at the LCD and see if it'll take a lower number; it might, might not, who knows.
    Jul 2006
    USA
    I'll try that. Thanks!
  1. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  2. Replies: 1
    Last Post: - 27th July 2008, 07:14
  3. PIC16F684 + 8*2 LCD module
    Last Post: - 6th March 2008, 00:38
  5. 16F84A and Optrex LCD
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 17th October 2005, 17:08
