Trouble with Optrex 4x20 LCD module
Results 1 to 8 of 8
    Quote Originally Posted by Brock View Post
    I'm having trouble with an Optrex 4x20 LCD module. I have had no problems
    with the 2x20 with a very similar program. It seems to ignore all "0"s in the
    text string. This is using the LCDOUT command in PBP. I tried slowing down the
    data with the defines, but it doesn't seem to help. If I put a pause in the main
    loop, so that it can't refresh the screen data as fast, then it works... for a
    while, then ignores the zeros again. Does the same thing weather in 4-bit or
    8-bit mode. Strange... and frustrating! Anyone have any ideas?
    How about seeing some code?
    What are your delay defines set as? The data_us define is an 8 bit value (something that isn't explicitly specified in the PBP manual), so if you set the data_us define as 257, you'll actually only get 1 (257-256). Keep that in mind. The command_us is a word value, so anything 0-65535 is good.
    Also, with all of the parallel type LCD's I've ever used, I usually keep command_us around 200, and data_us is around 50 (give or take). It's always worked for me.
    Maybe you're losing power somewhere and the LCD is blanking out because of it. Contrast going south? Who knows, let's see some code!
    Brock, Are you computing characters to send to it? Are there characters in the string that HOME the cursor? These characters take on an average of 1 millisecond and if your string of data is somewhat continuous then the display may be loosing characters.
    Jul 2006
    USA
    Post
    My bad. I had the lcdout subroutine improperly exiting...
    for example:
    GOSUB display
    disp_return: next line of code, and so on
    display: LCDOUT "blah, blah, blah"
    goto disp_return
    I copied the code from another program, but that program had a "IF, THEN"
    statement that determined what display subroutine to go to and I overlooked
    the new subroutine.
    Thanks for the help.
    for example:
    GOSUB display
    goto disp_return
    the new subroutine.
    DOH!!!!
    Jul 2006
    USA
    By the way, I use
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 100
    for the LCD timing. If you go faster on the data, such as 50 us, then
    the Optrex 4-line display will be garbled.
    By the way, I use
    Most likely, you can reduce that commandus down quite a bit, like I said, maybe 200.
    The dataus at 100, sounds good enough. Maybe throw another cap across the power/ground at the LCD and see if it'll take a lower number; it might, might not, who knows.
    Jul 2006
    USA
    I'll try that. Thanks!
  1. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  2. Replies: 1
    Last Post: - 27th July 2008, 07:14
  3. PIC16F684 + 8*2 LCD module
    Last Post: - 6th March 2008, 00:38
  5. 16F84A and Optrex LCD
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 17th October 2005, 17:08
