Use of Alphanumeric datas ?
Results 1 to 6 of 6
    May 2006
    Del Rio, TX, USA
    Have a look at Melanie's thread, Communications Example : PC to PIC bi-directional dialogue. This should give you a little tutorial on working with strings and serial comms. Read her code carefully, until you can see exactly what she has the PIC doing and how it handles the data. Then, not only will you probably have learned a couple of "tricks", but you should see at least a couple of possible solutions for you project.
    HTH,
    SteveB
    From pre-history... originally posted way back in 2002 to the PICBasic List...
    Hi Jim
    I threw this together for a giggle... (there's a secret message embedded within specially aimed it at you - and all the other budding radio hams out there)...
    This little ditty reads ASCII (in this case stored in EEPROM) and outputs Morse on a pin... all of EEPROM is read sequentially only stopping when it encounters an ASCII null ($00) or reaches the end of EEPROM space.
    Stick it in your favourite PIC, add a piezo transducer or speaker on PORTB.0 and enjoy...
    Melanie
        ' Hardware Assignments
        BeeperA var PORTB.0
            ' Hang your PIEZO Transducer on this pin
        ' EEPROM
            ' Supported Characters
            ' Alphabetic A-Z in upper or lowercase ASCII
            ' Numeric 0-9
            ' Special Characters ' () ch : , - / . ? "
            ' Note that ASCII space is used between words
            ' Data is terminated with an ASCII NUll ($00)
            ' This example isn't because it is exactly 64 bytes
            ' long and equals the variable EEPROMMax, so it will
            ' fit into a 16F84 with only 64 bytes EEPROM
        DATA @0,73,32,109,117,115,116,32,114,101,97,100,32,116,104,101
            ' I must read the
        DATA 32,80,73,67,66,65,83,73,67,32,109,97,110,117,97,108,32
            ' PICBASIC manual
        DATA 102,114,111,109,32,99,111,118,101,114,32,116,111,32
            ' from cover to
        DATA 99,111,118,101,114,32,68,101,32
            ' cover De
        DATA 74,73,77,32,66,65,76,76,83
            ' JIM BALLS
        ' RAM Assignments and Variables
        ASCIIData var byte
            ' variable holding the ASCII data to translate
        CounterA var byte
            ' General Purpose varable
        MorseBitPointer var byte
            ' bit pointer within MorseCode data byte
        MorseCode var byte
            ' translated Character for Morse Code Signalling
        MorseEnable var word
            ' Word Character for Flags and Morse Timing
        ToneOut var word
            ' Variable used in Beeper Tone Generation routine
        TonePitch var word
            ' Variable used to Time Pitch of Beep (in uS)
        ToneTime var word
            ' Variable used to Time length of Tone Beep (in mS)
        ' Program Constants
        DefaultBeepPitch con 185
            ' Default Tone Sound/Pitch (in uS)
        EEPROMMax con 64
            ' assumes this PIC has 64 bytes of EEPROM
        MorseDot con 10
            ' Time Interval for Dot (in 10mS increments)
            ' MorseDash would be 3*MorseDot
            ' MorseGap wpuld be 1*MorseDot (inter dot/dash space)
            ' MorseChar would 3*MorseDot (pause at end of character)
            ' MorseWord would be 8*MorseDot (pause at end of word)
        ' Start Program
        goto JumpStart
        ' Subroutine Nest Area
        ' Subroutine produces 2700Hz Beep
            ' ToneOut - tone loop counting variable
            ' TonePitch - variable determines PITCH of Beep (in uS)
            ' ToneTime - variable setting LENGTH of Beep (in mS)
    BeepOut:
        TonePitch=DefaultBeepPitch
    BeepRaw:
        For ToneOut=0 to ToneTime
            High BeeperA
            PauseUS TonePitch
            Low BeeperA
            PauseUS TonePitch
            Next ToneOut
        ' Subroutine Sounds Out Morse Character
    SendMorseCode:
        If MorseCode=$FF then
            ' Execute Word Pause
            MorseEnable=MorseDot*80
            Pause MorseEnable
        MorseEnable=0
            ' Reset Enable
        For MorseBitPointer=0 to 7
            ' Loop Up to 8 Times
            If MorseEnable=0 then
                ' Check for Character Start Flag
                If MorseCode.7=1 then MorseEnable=1
                ' Set Morse Character Start Flag
                ' If Morse sub-element Enabled, Send sub-element
                ToneTime=(50000/DefaultBeepPitch/10)*MorseDot
                ' Determine Morse Dot Time
                    ToneTime=ToneTime*3
                    ' Determine Morse Dash Time
                Gosub BeepOut
                ToneTime=MorseDot*10
                Pause ToneTime
            MorseCode=MorseCode<<1
            ' Shift to next Morse sub-element
            Next MorseBitPointer
        MorseEnable=MorseDot*30
            ' Determine & Execute End of Character Pause
        Pause MorseEnable
        ' Subroutine Translates ASCII to Morse
            ' in case you were wondering, it's written the
            ' way it is (with short Looup tables) to minimise
            ' possible word-wrap when emailing this text
    TranslateASCIIMorse:
        MorseCode=0
            ' Translate Numerics (0-9)
        If ASCIIData>47 then
            If ASCIIData<58 then
                Lookup (ASCIIData-53),[$20,$30,$38,$3C,$3E],MorseCode
                ' 5 6 7 8 9
            If ASCIIData<53 then
                Lookup (ASCIIData-48),[$3F,$2F,$27,$23,$21],MorseCode
                ' 0 1 2 3 4
            ' Translate Alphabetics (A-Z)
        If ASCIIData>96 then
            If ASCIIData<123 then ASCIIData=ASCIIData-32
        If ASCIIDATA>64 then
            If ASCIIData<91 then
                  Lookup (ASCIIData-82),[$0A,$08,$03,$09,$11,$0B,$19,$1B,$1C],MorseCode
                  ' R S T U V W X Y Z
            If ASCIIData<82 then
                  Lookup (ASCIIData-73),[$04,$17,$0D,$14,$07,$06,$0F,$16,$1D],MorseCode
                  ' I J K L M N O P Q
            If ASCIIData<73 then
                  Lookup (ASCIIData-65),[$05,$18,$1A,$0C,$02,$12,$0E,$10],MorseCode
                  ' A B C D E F G H
            ' Translate special characters
        If ASCIIData=39 then MorseCode=$5E
                ' ' Apostrophe
        If ASCIIData=40 then MorseCode=$6D
                ' ( Brackets
        If ASCIIData=41 then MorseCode=$6D
                ' ) Brackets
        If ASCIIData=58 then MorseCode=$78
                ' : Colon
        If ASCIIData=44 then MorseCode=$73
                ' , Comma
        If ASCIIData=45 then MorseCode=$61
                ' - Hyphen
        If ASCIIData=47 then MorseCode=$32
                ' / Oblique Stroke
        If ASCIIData=46 then MorseCode=$55
                ' . Period
        If ASCIIData=63 then MorseCode=$4C
                ' ? Question
        If ASCIIData=34 then MorseCode=$52
                ' " Quotation Moarks
            ' Translate Space
        If ASCIIData=32 then MorseCode=$FF
        ' End of Subroutine Nest Area
        ' Actual Start of Real Program
    JumpStart:
            ' Set Hardware Directions
        TRISB=%00000000
            ' Timeout to Reset Hardware
        Pause 250
        ' Read EEPROM and Output Morse
    RepeatLoop:
        For CounterA=0 to EEPROMMax-1
            Read CounterA,ASCIIData
            If ASCIIData=0 then goto ExitLoop
            Gosub TranslateAsciiMorse
            Gosub SendMorseCode
            Next CounterA
        ' Timeout 5 seconds and start all over again
    ExitLoop:
        Pause 5000
        Goto RepeatLoop
    France
    Thumbs up MORSE code
    Hllo Melanie
    Happy Happy year !
    As usual a very very good answer
    I will try to use it ..
    super MERCI
    Francois
  1. Alphanumeric lcd display suppliers
    By Sphere in forum Off Topic
    Last Post: - 27th April 2008, 13:40
  2. Adressing a 16 x 1 Alphanumeric LCD Display
    By crhomberg in forum mel PIC BASIC Pro
    Last Post: - 8th June 2007, 16:06
  3. Alphanumeric leds&16f84
    Last Post: - 7th February 2005, 19:03
  4. Displaying 32 bit datas on LCD
    By selahattin in forum General
    Last Post: - 12th January 2004, 11:55
