16f877 with LM335 problem
Results 1 to 40 of 47
    Hi, Cooter
    Your conversion formula is wrong ...
    °K = °C +273.15... and your scaling doesn't meet anything known.
    now, you MUST Download your sensor datasheet ... and wire it decently.
    Can't work at this time !!!
    Hi, Cooter
    Oh ya, that circuit's is out in the weeds somewhere.
    And when you do get it working, the easiest way I've found to calibrate the system is to dip the sensor in ice water and set the reading to match, not change any resistors or rewire anything, just adjust the math on the PIC to match.
    And are you sure the A/D is working right? Have you tried putting a pot across the A/D input? Does that respond correctly?
    Nov 2006
    Melbourne, Australia
    Angry 16f877 Adc Not Working
    hi all,
    am trying to understand how to implament the ADC on the pic 16f877
    my code is for a LM335 temp sensor connected to RA0(pin 2)
    the VDD and VSS is from a 7805 voltage reg that also supplies the LM335
    Cant get ADC to work from my circuit. or is it my code??????????????
    why cant i use decimal ie 0.46 in my maths routine?????????????
    This has had me up all week trying to get it to work
    PLZ someone guide me in the correct direction
    'PIC 16f877 with a LM335 temp sender
    define osc 20 ' 20mhz oscillator
    ' LCD ROUTINES
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4 '4,5,6,7
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    ' Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    define ADC_CLOCK 3 ' Set clock source
    AD_RAW var word ' Create adval to store result
    AD_RESULT var word
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %10001110 ' Set PORTA analog and RIGHT justify result
    ADCON0 = %10000001 ' Configure and turn on A/D Module
    Pause 500 ' Wait .5 second
    loop:
    ADCIN 0, AD_RAW ' Read channel 0 to ad_raw
    AD_RESULT = (ad_raw *0.48828) - 273.15 ' Convert Kelvins to Degrees C
    Lcdout $fe, 1 ' Clear LCD
    Lcdout "TEMP ", DEC AD_Result ," C" ' Display the decimal value
    Pause 100 ' Wait .1 second
    Goto loop ' Do it forever
    IF ITS STOCK IT WONT ROCK
    Default Here it goes again and again....
    Did you really bought the copy of PBP you have????
    Did it came with it a MANUAL ???
    Did you read the MANUAL ????
    Didn't find any reference as to that PBP is NOT supporting floating maths ???
    I am looking forward to you replying to the above so that we can continue support here.
    P.S. If you are just connect the sensor to the PIC directly, your useful range will be limited (0C-100C is from 2,7315 to 3,7315 Volts). I suggest to use opamps and extend the range of the sensor from 0C->0Volts to 100C->5 Volts.
    Amazing isn't it?
    Jun 2006
    Ton pethanes ton anthropo.
    Quote Originally Posted by savnik View Post
    Wish I spoke it!
    Even google'd it...everything came up in Greek. Imagine that! I'm lost
    Jun 2006
    You die the man
    You die the man
    Sorry,
    but what do you mean ??? ...
    Nov 2006
    Angry Still seeing red with the ADC
    thanks for the quick responce
    got PBP 2.47 from DONTRONICS here in melbourne
    Yes. Read the 213 pages and even been looking up web sites with references. downloaded the data sheet read the A2D converter module.. CH 11 pg 127
    ok just found 1 error in setting the TRISA had 8 bits set to 1 should have been 6 ie TRISA %111111 not TRISA %11111111
    still not workin. even connected a 5k lin pot and got no responce.
    and as Ioannis said using an opamp to extend the range i will be now
    MY CODE WILL NOT COMPILE WITH THIS LINE
    Had to do it this way
    ad_result = (ad_raw * 48828)/1000
    ad_result = ad_result/100
    ad_result = (ad_result *27315)/100
    WHY????????????????????????????????????????
    HMMMMMMM very frustrating
    Quote Originally Posted by CrazyCooter View Post
    What do you mean why? Did you read the post earlier? Did you really read it? Let me quote one line from that earlier post:
    "Did you read the MANUAL ????
    Didn't find any reference as to that PBP is NOT supporting floating maths ???"
    How many times do we have to point out to you that PBP does not support floating point math! And if you don't understand the term 'floating point', well, quite frankly 'floating point' means that the decimal is 'floating'...it can move wherever it needs to go according to the math being performed!
    PBP DOES NOT SUPPORT FLOATING POINT MATHS! The decimal point is stuck in one place, all the way to the right, no matter what you do, the decimal point will always be to the right...no fractions, no tenths, no hundreths, no nothing. If you divide 10 by 3, you'll get 3, nothing more nothing less. If you use the remainder function, yes, in the case above, you'll get a 1 from it, but it's still not FLOATING POINT...
    Somebody get me a drill!!!
    Nov 2006
    Smile
    Thanks skimask for pointing that out.
    ok so i am 1 step closer to getting this to work now.
    so the only way to do floating point maths then is with asm right?
    and thats why my code will not work correctly with the LM335 and the ADC?
    SWITZERLAND (french speaking)
    Default Any schematic to achieve this please?
    Can anyone please help me with a schematic on how to achieve what Ioannis is suggesting or is the example below not far away from what I'm looking for?
    How do I "electronically" rescale 2,7315Volts to an ideal "0V" and/or a 3,7315Volts to an ideal "5V"?
    I don't know...
    As I'd like to use my sensor to control a freezer, the temperature range I need goes from -30°C to +30°C.
    I found quite some info, for example here and I've already ordered some LM358 opamps to build this circuit.
    It looks like this circuit will output 0V at 0°C and 1V at 100°C. It is still "loosing" 4 precious volts, isn't it?
    How can this circuit be modified to, again ideally, match something like -30°C = 0V and +30°C = 5V?
    Roger
    Jan 2011
    Sydney, Australia
    Default Re: Any schematic to achieve this please?
    Why not use the LM35?
    This sensor is calibrated directly in Celcius, has a linear 10mV/degree C scale factor, is rated for -55 to +150 C range and does not require any external calibration or trimming to provide typical accuracies of =/-0.25C at room temperature and +/-0.75C over the full -55 to +150C range.
    Cheers
    Barry
    VK2XBP
    Thanks for the idea Barry.
    It's just, I have a LM335 in the drawer....
    I can give it a go with the LM35 - need to order one but here, in Switzerland, the LM35 is ten times more expensive than the LM335
    Anyway, I would still like to understand how the LM335 could be used with an opamp.
    Roger
  1. 16F877 HSERIN problem with 3th party software
    Last Post: - 11th March 2009, 18:11
  2. LCD problem with 16F877
    By alexx_57 in forum General
    Last Post: - 25th July 2007, 14:47
  3. problem using 16f877
    By yrch in forum mel PIC BASIC Pro
    Last Post: - 20th February 2006, 19:58
  4. 16F877 20MHz problem
    By swordman in forum mel PIC BASIC Pro
    Last Post: - 31st July 2004, 11:02
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 11:36
